Bt hub
Loonybin1973
Bt hub
I have been using aBT router with Plusnet since April. However over night the Bt hub isn’t working. I have plugged the Plusnet one in and that is working. Any ideas to get the Bt one working again please as I have been using the Wi-fi disc. Thank you
7 REPLIES 7
Fixes: 1,484
Re: Bt hub
Are the lights still blue on the router?
Loonybin1973
Re: Bt hub
No they’re orange on the Bt router. But the Plusnet Router is blue
Fixes: 1,484
Re: Bt hub
Have you checked that the username and password are correct on the BT router still?
Loonybin1973
Re: Bt hub
I tried logging on through the router IP address when the Bt home hub is plugged in but the page won’t open. I can do it when the Plusnet one is plugged in though
Loonybin1973
Re: Bt hub
How else do I check? Please
Loonybin1973
Re: Bt hub
Could really do with some help with this I am a nurse having to work form home and I cannot make contact with people without my internet the Plusnet router keeps kicking me out
Fixes: 420
Re: Bt hub
@Loonybin1973
If you have a disc are you using a Smarthub 2?. There have been reports of the odd Smarthub 6 losing their Plusnet log in credentials after a firmware update but not a failure to allow a log in. I have found when swapping hubs it is sometimes necessary to close down my browser, which presumably clears the cache and reopen it before trying  to access a different hub. Have you tried this or even a different browser?
If this fails have you tried doing a factory reset and setting it up again from scratch?
