Browsing is Slow
- Browsing is Slow
Browsing is Slow
27-05-2013 5:48 PM
I've had my fibre for about 3 weeks now and the speeds have been great (73 Mbps). However, browsing (latest Firefox) is slow with many sites taking over 10 seconds to appear. I'm connected via cable but it's still the same over wireless if I use my laptop. I re-installed Windows 8 a couple of days ago thinking that might help but it's still the same. How can I have such great download speeds but browsing is poor?
Message 1 of 7
(1,211 Views)
6 REPLIES 6
Re: Browsing is Slow
27-05-2013 5:58 PM
What's it like on chrome or Internet explorer
Message 2 of 7
(670 Views)
27-05-2013 6:21 PM
Quote from: zom414 I've had my fibre for about 3 weeks now and the speeds have been great (73 Mbps). However, browsing (latest Firefox) is slow with many sites taking over 10 seconds to appear. I'm connected via cable but it's still the same over wireless if I use my laptop. I re-installed Windows 8 a couple of days ago thinking that might help but it's still the same. How can I have such great download speeds but browsing is poor?
Traffic shaping policies giving speed test sites high priority maybe?
Message 3 of 7
(670 Views)
27-05-2013 6:52 PM
Quote from: thomasjc1 What's it like on chrome or Internet explorer
The same, getting rather annoying now too. I had to convince my wife to get fibre and even she notices the browsing is slower now than before. I'll give them a call and see if there's anything going on that shouldn't be.
Message 4 of 7
(670 Views)
27-05-2013 7:20 PM
This is probably a silly suggestion
Are you on Essentials Fibre and have you set the extra spend to zero and have you exceeded your 40GB usage
Message 5 of 7
(670 Views)
28-05-2013 3:14 PM
No, I'm on the unlimited fibre package.
jim:quote
jim:quote
Message 6 of 7
(670 Views)
28-05-2013 5:15 PM
Hiya zom414,
Given what's already been mentioned something is obviously just affecting browsing alone. That usually means a firewall issue, is there any particular security software you use that you could try and eliminate as a cause?
Adam
Adam
Message 7 of 7
(670 Views)
