Browsing certain websites fails
- Re: Browsing certain websites fails
04-09-2007 5:58 PM
In the past few weeks some of the websites I visit frequently during the day at work and home have stopped working on my plus.net connection.
I have tried everything I can think of as a network administrator, and can only put it down to a problem at plus.net's end.
Has anyone else experienced a similar problem?
http://www.debenhams.com won’t work, which I know works when I am at work, can anyone confirm if it works for them on their plus.net connection?
Many Thanks
Sam
Many Thanks
Sam
Message 1 of 7
(8,774 Views)
6 REPLIES 6
04-09-2007 6:00 PM
Working okay here on a PlusNet staff connection.
Message 2 of 7
(4,256 Views)
04-09-2007 6:05 PM
Great! anything else to add?!
Your tech support told me you help issues on this forum...
Message 3 of 7
(4,256 Views)
04-09-2007 6:13 PM
It works from the office here, and also from my home connection.
What error messages do you get, if any? Does it fail in a different browser? Have you tried removing all temporary internet files/cookies? Have you tried using alternative DNS servers?
If you run a traceroute to debenhams.com, where is the last hop?
Message 4 of 7
(4,256 Views)
04-09-2007 6:47 PM
Just to add. My browser jumps straight to it. It sounds like a browser issue. Did clearing out the cache and cookies help?
Message 5 of 7
(4,256 Views)
04-09-2007 8:05 PM
I have just tried accessing Debenhams using Internet Explorer, Opera, Safari, and Firefox and all four browsers worked fine.
It sounds as though it is something related to your browser - I would remove all your cookies and clear any caches that are maintained and see if any improvement is forthcoming.
Regards,
Davidhil
Regards,
Davidhil
Message 6 of 7
(4,256 Views)
05-09-2007 8:05 AM
got to the bottom of it!
Seems as though peerguardian was running, with nothing in the tray bay and also with HTTP blocked!
thanks for the advise.
Message 7 of 7
(4,256 Views)
