Broken boadband: Ping works as far as gateway router but no further :(
- Re: Broken boadband: Ping works as far as gateway ...
14-07-2014 12:23 AM
Hi - I have a weirdly broken broadband connection - any thoughts on what the problem might be?
DSL connection working, modem connects and is assigned a WAN side IP address, PN gateway router address and DNS server adddresses,
However no internet connection
Tracert shows 2 or 3 working hops but nothing more:
hop 1: laptop to adsl modem
hop 2: adsl modem to PN gateway router
(hop 3 PN gateway router to anothe PN device)
after that no other hops respond.
Modem tested on different line/ISP ok
Any thoughts on tests I can do/settings to change to help
Message 1 of 4
(803 Views)
3 REPLIES 3
Re: Broken boadband: Ping works as far as gateway router but no further :(
14-07-2014 11:26 AM
Your connection seems quite intermittent. I'm wondering if this is part of the problem.
<img src="http://community.plus.net/visualradius/generated/image1405333548836.png"/>
Are any of the above drops yourself resetting the router?
Message 2 of 4
(464 Views)
14-07-2014 11:48 AM
I had the same problem at the end of May, and there has been at least one other instance for someone else a couple of weeks later.
http://community.plus.net/forum/index.php/topic,127467.0.html
Message 3 of 4
(464 Views)
14-07-2014 11:03 PM
Chris - I can probably account for all but 3 of the disconnects - the vast majority are definitely me rebooting/changing connection settings. the three that I probably cant account for are wed 9th at 2.30am, fri 11 @1.30am and mon 14th @ 10.30am.
Interestingly I am now replying using a now working connection. Somewhere netween last night [sun] and this morning @8am things came good, ?????????
Message 4 of 4
(464 Views)
