Broadband width
- Broadband width
Broadband width
28-11-2017 11:34 AM
I have been unable to access systems on line for last couple of days, taken an hour to get to this page, messages from laptop and ipad is broadband width not enough. I know it is busy time but can it be increased?
Re: Broadband width
28-11-2017 12:05 PM
A warm welcome to the forums. That's an odd message - how are you connecting to the router - wifi or wired (Ethernet)? Its worth while checking out all of the basics which you can do yourself - see the speed issues link below.
Broadband is not going to work well if the "phone" line is not working properly.
Please perform a quiet line test - dial 17070 select option 2 using a corded phone plugged into the test socket behind the face plate of the master socket. It should be silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of broadband.
If the line is noisy or there is no dial tone, then a PHONE LINE fault needs to be raised with your phone provider. If this is PlusNet, you can report a fault on line using the button below. From the Q&A list, choose the one which matches the problem, 'open' the 'section' and click the trouble-shooter link. NB: If you receive a failure message (rather than a log-in prompt) then log-in to the user portal in a different browser tab and attempt to use the trouble-shooter again.
What are the expectations for your line?
Please use the following links to check the services available and their estimated speeds. From the first link, please record and report back the distance from the exchange. The second link advises of which fibre services (if any) are available on your line and their anticipated speed.
How is your line performing?
Please post your router stats; for PN TG582n and 2704n routers use the buttons below, for other routers look at the Kitz link.
Also run a BT Wholesale speed test (ideally using an Ethernet wired PC with the WiFi turned off) then run the further diagnostics and post the results here. DO NOT REBOOT the router!
Also find your CURRENT SPEED (PlusNet line profile) from the PlusNet user portal - you will need to log in.
