Broadband speed
- Broadband speed
Broadband speed
14-10-2009 11:30 AM
Dear group....since 2nd of October Ihave been with Plus net but since then no e mail access as in previous posts.....My other problem is line speed....480kbps down and 360 up......I am on unlimited access up to 8mb is anyone getting anything like 8mb???I am 800 metres away from the exchange...cheers to all Barrie g4yjs.
Message 1 of 5
(1,041 Views)
4 REPLIES 4
Re: Broadband speed
14-10-2009 11:36 AM
Hi Barrie,
It appears that for some reason, BT are limiting your potential speeds. From memory it'll problably be a BT RAS server misconfiguration, but I've placed an order to try and avoid our needing to raise a fault (which will take longer).
Can you try it again tomorrow and see how you get on?
Also useful reading: link:speed
Message 2 of 5
(395 Views)
Re: Broadband speed
14-10-2009 11:48 AM
Many thanks James for the speedy reply.....looking forward to further updates cheers Barrie g4yjs.
Message 3 of 5
(395 Views)
Re: Broadband speed
16-10-2009 5:15 AM
Dear James and group.....had a call last night from link:csa removed....after carrying out a series of tests he suspects a faulty router(line was un capped yesterday by B.T)But it is still only syncing at 500 kbps.He is sending out a test router so I will keep the group up to date...cheers to all Barrie g4yjs
adie:red CSA name removed as per link:rules]
Message 4 of 5
(395 Views)
Re: Broadband speed
16-10-2009 10:29 AM
Thanks for letting us know Barrie, hopefully the router will sort out the issues you've been seeing.
Message 5 of 5
(395 Views)
