Broadband speed
- Broadband speed
Broadband speed
24-08-2020 9:05 PM
Hello
I have just checked my broadband speed and it seems very slow
Download 3.34
Upload 0.3
Am I right in saying it should be around 10?
Re: Broadband speed
24-08-2020 9:27 PM
@SteveW66 If you are on ADSL, in theory under IDEAL conditions, you could get 21Mb/s, but that is highly unlikely.
What is your normal speed, and what does the BT DSL checker say you should be getting? As I suspect you have a fault please read the following:
Plusnet staff support, like the phone service, is still severely restricted. If you would like help from the community, a good starting point is to have a look at This post and supply as much detail from it as possible.
It would also be a good idea to carry out a 'Quiet Line Test' - dial 17070 from a (preferably corded) phone and select option 2 - there should be no discernable noise. If there is, report a phone fault first, as without a clear phone connection, your broadband will not perform correctly.
If you reply to this topic with as much detail as possible, there are plenty of experienced members who can advise on possible remedies.
Re: Broadband speed
24-08-2020 11:08 PM
Hi
Thanks for the reply
BT DSL checker says I should get 49 - 70.4 Download
and 11.9 -18.2 upload speeds
So something is wrong
I have done the quiet line test and that's ok
Steve
Re: Broadband speed
25-08-2020 6:57 AM
@SteveW66 So you are on Fibre, not ADSL? Please confirm.
Re: Broadband speed
25-08-2020 8:20 AM
Sorry...No I'm not on fibre...
Am I reading the wrong figures?
Re: Broadband speed
25-08-2020 8:31 AM
Yes you are - you should be reading the ADSL/ADSL2 figures.
Re: Broadband speed
25-08-2020 10:04 AM
Hi
The figures are:
ADSL2 up to 4.5
ADSL max up to 1.5
It's probably just the area I am in
Re: Broadband speed
25-08-2020 5:49 PM
@SteveW66 Sorry for the delayed response, but just to satisfy my curiuosity, could you run this test, preferably posting screenshots, as they give better information:
Result of a BT speedtest from here but only for IP profiles. If you want a full speed check use this https://speedtest.btwholesale.com/ and then Further diagnostics for the IP profiles. Please connect to the test socket if you can, this helps us rule out problems with cabling and sockets in your home.
Please run the second link, and be sure to run and report the 'Further diagnostics'.
Re: Broadband speed
27-08-2020 4:51 PM
Hi John
I have posted screenshots and it seems like it is acceptable for this area..
Best wishes
Steve
Re: Broadband speed
27-08-2020 5:25 PM - edited 27-08-2020 5:30 PM
If you want to look at what speed you should get against what you are getting, running data speed tests is not going to help any, for they can only report what you are actually getting, not what the line is capable of. Sync speed dictates the line profile, which limits the achievable data speed. Therefore if the achieved data speed is in the realms of the profile speed, it is deemed "acceptable".
You need a baseline, which is assessed by science (rather than the BTw speed estimate) based on the characteristics of YOUR line. Sight of your FULL router stats would be helpful please. Be sure to include
- Actual line speed
- Max line speed (if given)
- SNR / SNRM
- Attenuation <- this is the key figure in determining the line's potential
Broadband is not going to work well if the "phone" line is not working properly.
Please perform a quiet line test - dial 17070 select option 2 using a corded phone plugged into the test socket behind the face plate of the master socket. It should be silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of broadband.
If the line is noisy or there is no dial tone, then a PHONE LINE fault needs to be raised with your phone provider. If this is PlusNet, you can report a fault on line using the button below. From the Q&A list, choose the one which matches the problem, 'open' the 'section' and click the trouble-shooter link. NB: If you receive a failure message (rather than a log-in prompt) then log-in to the user portal in a different browser tab and attempt to use the trouble-shooter again.
Re: Broadband speed
29-08-2020 5:16 PM
Thanks for the reply....
I have tried the quiet line test but not from the test socket.....It does seem to be ok
I'll try your other suggestions next week..
Regards
Steve
Re: Broadband speed
05-09-2020 6:19 PM - edited 05-09-2020 6:21 PM
Off topic stuff and collateral damage moved elsewhere.
