Broadband speed slow - Customer support speed = SLOWER STILL
- Broadband speed slow - Customer support speed = SL...
Re:Broadband speed slow - Customer support speed = SLOWER STILL
05-11-2009 10:46 PM
Re: Broadband speed slow - Customer support speed = SLOWER STILL
05-11-2009 10:50 PM
05-11-2009 10:54 PM
@ Mand
will these be of any use to you?
Service VPI/VCI Protocol Received Transmitted
Bytes Pkts Errs Drops Bytes Pkts Errs Drops
wizard_pvc 0/38 PPPoA 0 0 0 0 0 0 0 0
LAN Statistics
Interface
Received
Transmitted
Ethernet 0 0 0 0 384 6 0 0
Wireless 337552192 1039460 0 0 1846072379 1522346 17 0
ADSL Statistics
Mode: G.DMT
Type: Interleave
Line Coding: Trellis On
Status: No Defect
Downstream Upstream
Rate (Kbps): 1120 448
SNR Margin (dB): 7.6 19.0
Attenuation (dB): 63.5 25.0
Output Power (dBm): 12.3 17.3
Super Frames: 7485683 7485681
Super Frame Errors: 1151 2
RS Words: 127256614 63628288
RS Correctable Errors: 35977 25
RS Uncorrectable Errors: 6254 N/A
HEC Errors: 1017 1
OCD Errors: 15 0
LCD Errors: 0 0
Total Cells: 336145302 0
Data Cells: 38585651 0
Bit Errors: 0 0
Total ES: 727 0
Total SES: 1 0
Total UAS: 13 0
@ Pierre.
Thanks... got my manual out ! !
05-11-2009 10:59 PM
Quote from: shutter Downstream Upstream
You're never going to get great speeds because of how far you are from the exchange (the attenuation tells us that).
Can you plug the router in to the test socket inside the master socket - with no phones or anything else connected and post what you get for the above data then please.
05-11-2009 11:07 PM
As far as the "internal wiring" and connections are concerned. NOTHING, repeat NOTHING has been changed/move/rewired/re-worked/removed prior to 1 November 2009.
Therefore... ipso facto. if the wiring is the same then the speed should also be the same....
as mentioned earlier in this post.... I could regularly achieve 1.4 mbs on a day to day basis. it was rock solid... although a couple of times I do remember being pleasantly surprised and seeing 1.7 mbs and yes that was using the BT speed tester... (as a point of interest the www.speedtest.net uses the same OOKLA engine as the plusnet tester.)
The speed has dropped from 1.4 to 0.7 from the changeover of product. which is absolutely stupid....
05-11-2009 11:17 PM
Unfortunately, because your speed is in BT's acceptable range, unless the test socket shows something different, I fear there's not much that can be done.
Edit: A thought - there isn't any background noise on the phone when you use it is there?
05-11-2009 11:24 PM
I did notice "interleave" was mentioned in the stats... does that have any affect?
I also notice there are a lot of posts below this one of mine, regarding a drop in speed on the change over of products..... sounds fishy to me...
EDIT EDIT EDIT
I shall have a go at the test socket tomorrow moring if I can get to it !.
05-11-2009 11:33 PM
The BT IP Profile you now have is below the speeds you were getting previously so I'm almost positive it's nothing to do with the account change.
05-11-2009 11:36 PM
If not, I will only have to wait another 24 hours for Plusnet CSA to get back to me regarding my ticket....
Goodnight all
06-11-2009 8:26 AM
Just checked the BT speedtester and their "best effort" is again less than what they profile..... a miserable 608kbs ..
One thing I remembered last night after I shut down the computer..... My profile when I was getting 1.4 mbs (which I was quite happy with) was 1250, so I know the line is capable of the speed, and as mentioned before, nothing has changed EXCEPT the package I am on...
On that subject..... My package changed at 0001 on 1 November 2009, (Saturday night/Sunday morning.... I had a connection all day on Sunday , yet on Monday the 2nd I woke up to NO connection.... which is why I contacted CS by phone... Surely this should not have happened..... after all , it (the changeover) is only and admin job, changing letters and numbers on a computer database and should not have affected my connection..... especially 24 hours after the event.
06-11-2009 8:47 AM
WE ALL SEEMED TO HAVE MISSED THAT ON YOUR FIRST POST
06-11-2009 8:55 AM
06-11-2009 8:59 AM
06-11-2009 9:00 AM
06-11-2009 9:03 AM
