Broadband speed issue - router thinks it's fine(!) Anyone else seeing this?
- Broadband speed issue - router thinks it's fine(!)...
- « Previous
- 1
- 2
- Next »
Re: Broadband speed issue - router thinks it's fine(!) Anyone else seeing this?
09-02-2014 12:38 PM
Ok - after realising that FEC / HEC / CRC was nothing to do with BAK / SAK & CRAK .... I hit the interwebs to try and decypher the TLA conundrum.
After hours and hours of searching (about 30mins really) I finally stumbled upon a thread that showed a tool that could get these mystical stats.
In case anyone else is new to this type of diagnosis and doesn't have a clue about the terminology ... check this link: http://vwlowen.m3ezw.co.uk/phpBB3/viewtopic.php?t=398
Nirvanna
So, app installed and even did the hoopy telnet mod to access the advanced stats.
Behold ..... numbers ... and a graph (woot!)
Nirvanna
Downstream:
Noise Margin: 15.1 dB
Connection Rate: 13960 Kbps
Line Attenuation: 24.5 dB
Power: 0.0 dBm
Max Rate: 16100 Kbps
SuperFrames: 5545464
SF (CRC) Errors: 85
Reed Solomon: 720910150
RS Corrected: 18685
RS Un-Corrected: 1912
HEC: 1562
Errored Seconds: 286
Severe ES: 10
Interleave Depth: 64
Bitswaps: 805
Upstream:
Noise Margin: 6.5 dB
Connection Rate: 1150 Kbps
Line Attenuation: 12.6 dB
Power: 11.6 dBm
Max Rate: 1152 Kbps
SuperFrames: 334022
SF (CRC) Errors: 10
Reed Solomon: 4289178
RS Corrected: 42
RS Un-Corrected: 0
HEC: 10
Errored Seconds: 6
Severe ES: 0
Interleave Depth: 4
Bitswaps: 0
Total Uptimes (From SF counts):
WAN: 1 days, 02:11:54
LAN: 0 days, 00:00:00
Message 16 of 19
(423 Views)
10-02-2014 2:08 AM
I took both my old DG834PN and new DGND3700v2 to my dad's house tonight (he uses PN too) and tested them there.
His line speed is 3-3.5Mb and I was getting that no problem with both of the routers ... using my own microfilter, RJ11 etc.
I kind of knew this would be the case, but this proves that the hardware that I have is fine.
The BT engineer said the line was clean (and I hear no artifacts on the phone) so logically it must be either the exchange or there's some policy restricting my account.
Message 17 of 19
(423 Views)
10-02-2014 10:41 AM
I can see that your Fault Ticket is back with our Faults Team. They will be in touch once their further investigation has been completed.
Message 18 of 19
(423 Views)
11-02-2014 3:32 PM
New stats ....
System Up Time 38:50:25
Download:
Noise Margin: 15.6 dB
Connection Rate: 14070 Kbps
Power: 0.0 dBm
Max Rate: 16492 Kbps
SuperFrames: 8615927
SF (CRC) Errors: 6777
Reed Solomon: 1120070349
RS Corrected: 2955846
RS Un-Corrected: 26070
HEC: 23324
Errored Seconds: 4965
Severe ES: 0
Bitswaps: 449
Upload:
Noise Margin: 6.4 dB
Connection Rate: 1176 Kbps
Power: 12.0 dBm
Max Rate: 1184 Kbps
SuperFrames: 304912
SF (CRC) Errors: 14
Reed Solomon: 2055703
RS Corrected: 0
RS Un-Corrected: 0
HEC: 10
Errored Seconds: 11
Severe ES: 0
Interleave Depth: 1
Bitswaps: 0
Message 19 of 19
(423 Views)
- « Previous
- 1
- 2
- Next »
