Broadband speed checker
- Re: Broadband speed checker
18-07-2012 5:45 PM
The following message has been on the Plusnet broadband speed checker for weeks,
Sorry - My Broadband Speed is currently experiencing technical difficulty and may display misleading test results. Thanks for bearing with us while we fix things.
Seems to be giving me the results I would expect, I know it says, ' may display misleading results ' but is it fixed with this being an old message ?
We are born into history and history is born into us.
Message 1 of 3
(970 Views)
2 REPLIES 2
18-07-2012 6:02 PM
Gave me expected results this morning. I understood from a post on here a while back that it gave misleading results when it was under heavy load - presumably that means the server can't cope
Message 2 of 3
(550 Views)
18-07-2012 7:59 PM
I've been checking it regularly over the last couple of weeks and it seems to be working just fine now. The results it gives match almost exactly what I get from other speedcheck sites.
I suspect this is because very few people use it now and so it doesn't get overloaded.
Message 3 of 3
(550 Views)
