Broadband speed absolutely dire
- Broadband speed absolutely dire
Re: Broadband speed absolutely dire
28-09-2014 11:25 AM
28-09-2014 11:26 AM
28-09-2014 11:31 AM
Quote from: lindap did you need this?
DSL Connection
Link Information
Uptime: 1 day, 19:19:10
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,063 / 4,295
Data Transferred (Sent/Received) [MB/GB]: 378.03 / 6.34
No, this http://192.168.1.254/cgi/b/dsl/dt/?be=0&l0=2&l1=0 is what is needed please as per that provided last time (see post #2 in this merged thread).
Edited to include quote after Jim's post pushed this over a page boundary
28-09-2014 11:32 AM
will try again
28-09-2014 11:35 AM
Use the thinkbroadband test - that gives some far more useful information or the one Jim linked.
28-09-2014 11:37 AM
Jelv,
Either I miss read your original post or you edited it quickly that it did not get marked as edited!
28-09-2014 11:39 AM
looks as if its cured, what do you think?
28-09-2014 11:41 AM
Not cured at all, symptoms fixed yes, but cause not identified.
Can you please post your current router stats as requested above?
28-09-2014 11:42 AM
Quote from: Townman rather the PlusNET speed test, which I have just tried and does not appear to be working...
PN speed tester is working fine here
Re: Broadband speed absolutely dire. Upload speed 0.36mbps download speed 0.51mbps.
28-09-2014 11:44 AM
Quote from: Townman Jelv,
I like your thinking - PlusNET profile change without a PPP drop...
Then that would be very similar to the previous scenario. Under some unidentified condition the line is synching up with a very poor synch speed and cascading a low profile delta to PlusNET.
If this action "fixes" the current symptoms, then the cause of intermittent slow synchs needs investigating.
Kevin
Suspicions confirmed and I think we are all agreed on what needs to be done now.
(and yes it was a quick edit)
28-09-2014 11:46 AM
DSL Connection
Link Information
Uptime: 1 day, 19:52:19
Data Transferred (Sent/Received) [MB/GB]: 386.17 / 6.38
Output Power (Up/Down) [dBm]: 12.6 / 0.0
Line Attenuation (Up/Down) [dB]: 27.5 / 49.0
SN Margin (Up/Down) [dB]: 6.2 / 10.3
Loss of Framing (Local/Remote): 27 / 0
Loss of Signal (Local/Remote): 17 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 7,417 / 2
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 530 / 27,074
HEC Errors (Up/Down): 379 / 128,900
28-09-2014 11:47 AM
Quote from: lindap Today 11:37 3698 kbps (462kB/s) 899 kbps (112kB/s)
It's not cured, we've just fixed the symptoms. We need to find out why it is occasionally syncing at very slow speed - until that is addressed it's likely to keep happening.
28-09-2014 11:49 AM
Quote from: lindap Uptime: 1 day, 19:52:19
Are you aware of anything happening Friday afternoon that might have affected your connection?
28-09-2014 11:52 AM
Your noise margin is too high which indicates that the automatic systems are seeing instability and this is probably the occasional very low sync events
Can I suggest installing Routerstats (I assume you have a Windows Computer) http://www.vwlowen.co.uk/internet/files.htm
Note to others - the reason why I say the stats aren't to bad is that they are better than mine. Note my line is just not very good
Noise Margin: 5.0 dB
Bandwidth: 3811 kbps
Attenuation: 50.0 dB
28-09-2014 11:53 AM
