Broadband slowed to a crawl
- Broadband slowed to a crawl
- « Previous
- Next »
Re: Broadband slowed to a crawl
11-11-2008 3:21 PM
No rate limitations other than what's already on the Portal.
We don't specifically rate limit Broadband Plus web traffic.
Message 31 of 38
(380 Views)
12-11-2008 12:00 AM
Today's tests:
11/11/08 14:15
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 6272 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 5500 kbps
Actual IP throughput achieved during the test was - 5100 kbps
My broadband speed 5315 down 382 up
Speedtest.net 5325 down 379 up
11/11/08 18:10
Actual IP throughput achieved during the test was - 881 kbps
My broadband speed 1079 down, 382 up
Speedtest.net 1001 down 378 up
11/11/08 23:24
Actual IP throughput achieved during the test was - 4348 kbps
My broadband speed 5318 Kbps down 383 up
Speedtest.net 5293 Kbps down 378 Kbps up
There is definitely something severely limiting my download speed during the early evening and it seems to me that the problem must either be due to BT or Plusnet.
James - if you are still reading this thread, is there anything that Plusnet can do to investigate this further?
I will be in hospital for some tests on myself for the next three days, so I will not be able to do any more speed tests until the weekend.
11/11/08 18:10
11/11/08 23:24
Message 32 of 38
(380 Views)
12-11-2008 9:10 AM
We're looking into this further today to see what we can do to address this. Sorry about the problems.
Message 33 of 38
(380 Views)
12-11-2008 9:35 AM
[iurl=http://community.plus.net/forum/index.php/topic,70503.0.html]Recent peak-time speed problems - Please read this![/iurl]
Message 34 of 38
(380 Views)
14-11-2008 2:47 PM
Glad to know I'm not alone at last.
I thought there must be something wrong 'up-the-line' rather than at my end, because of the reasonable speeds I have been getting off peak.
Message 35 of 38
(380 Views)
08-12-2008 12:03 PM
Things are steadily improving.
11:45 This morning 8 December 2008
DSL Connection rate 7488 Kbps downstream 448 Kbps upstream
IP profile for your line is 6500 kbps
Actual IP throughput achieved during the test was 4691 Kbps.
Throuput seems a little low on this test - My Broadband speed tester is regularly reporting speeds around 5200kbps
Message 36 of 38
(380 Views)
13-01-2009 4:52 PM
Still on a long temporary extension lead - but if it works don't fix it.
Today's test 13 Jan 2009 at 16:15
Your DSL connection rate 7904 kbps (downstream) 448 kbps (upstream)
IP profile for your line is - 6500 kbps
Actual IP throughput achieved during the test was - 5275 kbps
The My Broadband speed tester showed download of 6147 kbps
Speedtest.net speed tester showed download of 6322 kbps
I think these are some of the fastest download speeds I have ever achieved.
I have also recently been getting much faster uploads to my webspace, with none of the long pauses and dropped files I used to experience.
Message 37 of 38
(380 Views)
19-02-2009 6:32 PM
Another improvement
Tonight's test at peak time 19 Feb 2009 at 18:04
Your DSL connection rate: 8128 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 7150 kbps
Actual IP throughput achieved during the test was - 5790 kbps
Speedtest.net gives a download test result of 6445 Kbps - not bad for peak evening time
It can't get much better than this on an 'up to' 8Mb connection
Message 38 of 38
(380 Views)
- « Previous
- Next »
