Broadband seems slow ????
- Re: Broadband seems slow ????
14-10-2008 1:19 AM
I've run some speed tests and wonder if anyone can tell me if I have a problem. I am on Premier Plus up to 8Mb
Date Download Speed Upload Speed
Today 01:07 2270 kbps (284kB/s) 353 kbps (44.1kB/s) Share
Today 00:45 2242 kbps (280kB/s) 358 kbps (44.8kB/s) Share
Sunday 22:17 2318 kbps (290kB/s) 359 kbps (44.9kB/s) Share
Sunday 15:07 2257 kbps (282kB/s) 307 kbps (38.4kB/s) Share
Sunday 14:58 2201 kbps (275kB/s) 344 kbps (43kB/s) Share
Mar 7, 21:51 4212 kbps (527kB/s) 378 kbps (47.3kB/s) Share
Mar 7, 21:20 3622 kbps (453kB/s) 378 kbps (47.3kB/s) Share
Result for the BT speed test are -
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 7616 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 6500 kbps
Actual IP throughput achieved during the test was - 5609 kbps
If you wish to discuss these results please contact your ISP.
Message 1 of 9
(1,765 Views)
8 REPLIES 8
14-10-2008 7:58 AM
where do you get the non BT speed tests from, they dont look correct, i.e. half the BT test, not normal
try http://www.mybroadbandspeed.co.uk/ The PlusNet one
Message 2 of 9
(771 Views)
14-10-2008 8:39 AM
When the BT Speedtester and an external speedtester show such a wide difference, the cause is usually incorrect MTU and RWIN settings on your local machine.
Try changing the RWIN/MTU, rebooting your machine (very important!) and then posting your external speedtest results.
B.
B.
Message 3 of 9
(771 Views)
14-10-2008 8:42 AM
but he did get on the BT test
which doesn't to me look like RWIN, mind you not my area of expertise
Quote Actual IP throughput achieved during the test was - 5609 kbps
Message 4 of 9
(771 Views)
14-10-2008 8:54 AM
Pierre,
This is very common - honestly!
If the BT Speedtester shows substantially higher throughput speeds (in this case 5609Kbps) over an external speedtest (2270Kbps) the cause is 99.9% of the time RWIN settings.
B.
B.
Message 5 of 9
(771 Views)
14-10-2008 9:03 AM
Agree. I know from practical experience on many systems that the BT Speedtester is relatively insensitive to inappropriate MTU/RWIN.
That's one reason why it's such an important tool.
The question is why? Does anyone know what trick they use?
Message 6 of 9
(771 Views)
14-10-2008 5:46 PM
Quote from: pierre_pierre where do you get the non BT speed tests from, they dont look correct, i.e. half the BT test, not normal
That is where I got the non BT speed test from.
Message 7 of 9
(771 Views)
14-10-2008 6:12 PM
Quote from: Barry When the BT Speedtester and an external speedtester show such a wide difference, the cause is usually incorrect MTU and RWIN settings on your local machine.
B.
Done that and run the Plus Net speed test and todays result shows a marked improvement thanks.
Today 18:07 3711 kbps (464kB/s) 353 kbps (44.1kB/s) Share
Message 8 of 9
(771 Views)
14-10-2008 6:45 PM
Glad to help
B.
B.
Message 9 of 9
(771 Views)
