Broadband outage
- ADSL Broadband
- Re: Broadband outage
- « Previous
- 1
- 2
- Next »
30-10-2010 10:11 AM
Thought sod it off to bed, everything powered off.. Tried this morning and it connected at 9am, then got the service emails saying the Edinburgh exchange was down (CapX) Thought hmm
Now another saying it is still down in some areas, lucky me I am connected
30-10-2010 10:12 AM
30-10-2010 10:15 AM
BT BT said engineering teams worked throughout the night to resolve the technical issue
A technical fault that left tens of thousands of homes without internet broadband has been fixed, BT has said.
The company said the problems affected a "significant part of the UK", including Northern Ireland, Scotland and northern England, on Friday night.
Engineers worked through the night to correct the fault at an exchange in the Edinburgh area, BT said in a statement.
A spokesman said the situation was being monitored and phone services had not been not affected.
"Following a technical fault at an exchange in the Edinburgh area last night which caused disruption to some broadband services, BT confirms that all services have been restored to customers," he said.
"BT's engineering teams worked throughout the night to resolve outstanding customer issues and to monitor the performance of the network."
http://www.bbc.co.uk/news/uk-northern-ireland-11656851
30-10-2010 10:51 AM
30-10-2010 11:15 AM
original post edited
Quote from: Hairy @Oldjim there has been another one since then saying some are still effected
30-10-2010 11:21 AM
I spent the time finishing off single player campaigns on the PS3, always good to leave some levels unfinished just for times like this
30-10-2010 11:21 AM
Quote from: fourfourdevon I'm afraid a ring wouldn't rate as resilient in my book two points of failure and you divide the network in two.
You're missing my point. Telephones used circuit switching. For resiliency they used interconnected rings, a system known as SDH in Europe and SONET in North America. Typically these systems are rated to have a 99.999% uptime. Anything with 50% spare capacity is extremely resilient and very expensive, because you pay for twice the capacity you use, until you get a failure.
Internet traffic is designed around packet switching and a mesh architecture. Yes, this was designed to be highly resilient but does this work in practise when different parts of the internet network are controlled by different companies? It's no good saying it is resilient when self-evidently BT's bit wasn't. Maybe BT could have re-routed their lost internet traffic via somebody else's network but they didn't want to pay the cost of doing that? Or maybe they sacrificed resiliency to make their internet service cheap? Any resiliency requires that you have more capacity than you need when the network is fully operational and spare capcity is expensive.
30-10-2010 11:39 AM
30-10-2010 11:46 AM
A resilient network (and I mean IP network) is one where your network are able to deal with the problem at hand (the "internet" is a network of networks). And I know resilient systems are expensive, I used to design, build and maintain resilient network (IP) systems, not on the scale BT does or needs to, but I still did it. The issue of resilience of the "internet" is irrelevant to this discussion since the internet was in effect unaffected, it doesn't seem that BT lost the ability route traffic around its network, if it had I think the problem would have been hitting more people with different types of problems, this was a problem as best as I can see of authentication, or some part of the identification process, and for some bizarre reason, great swathes of the country seem to be wholly reliant on the Edinborough exchange for this.
There is no, on the surface of it, reason for this, BT could have multiple identification/authentication systems distributed across its IP network, all capable of performing the job needed, and say on a bad day 100 identification/authentication units are needed to get the job done, distributing a further 25 units around the network would mean BT could loose 20% of its identification/authentication capacity before there would be any degregation in service.
30-10-2010 1:40 PM
30-10-2010 3:14 PM
20CN Connectivity Issues (64225) - NEW
Internet Connectivity
Posted on: Saturday 30 October 2010, 14:46
We have been made aware that a number of customers are not able to connect to the internet on the 20CN network. This seems to be effecting the North of England, Northern Ireland and Scotland.
Updates will be posted when they are available.
Please accept our apologies for any inconvenience this may cause.
Kind Regards,
Jonathon Smith
Customer Support
30-10-2010 4:28 PM
31-10-2010 1:10 AM
30/10/2010 @ 23:01 20CN Connectivity Issues (64225) - RESOLVED
This is a further update to the previous postings about problems connecting to the broadband network yesterday and today.
We are glad to advise that service has been restored and customers previously affected by this issue should now be able to connect successfully. This has been fully confirmed with our suppliers.
If you are unable to get back on-line then please power your broadband equipment off for 10 minutes before trying to reconnect. If this is unsuccessful, please contact the Support Team through the usual channels.
We are sorry for any inconvenience this may have caused.
Regards, Craig Furniss
However I still cannot connect to my broadband - so phoned up customer service and was advised that it was an "ongoing issue" when I asked how long it would be ongoing for I was advised to check every hour... and then eventually told that it could be ongoing until Tuesday.
Quote from: between1and16cha Can someone help me to understand why I was outright refused dialup access by the faults reporting line last night when I asked for access due to the broadband outage? I'm too rural here for mobile coverage, so can't have that as a backup, and since it's been offered in the past, I hadn't got an alternative dial-up emergency provider prepared.
We are quite rural too (which is probably why it will take longer for our internet to be fixed *rolls eyes*) however I was fortunate enough to be able to nip to my mums and hog her internet. I checked all the mobile broadband providers and luckily enough (and much to my surprise) Three offer coverage where we are - they were the only provider who did... I nipped to Argos and got a PAYG dongle thing (and tbh it seems just as fast as the broadband plusnet normally provide me with!)
31-10-2010 6:37 AM
Its not just you there seems to be a rather large number of people in the north of the UK in the same problem
31-10-2010 8:26 AM
NOPE!! It isn't resolved for everyone, obviously.
I still can't connect and have been told that it might be down until tuesday! I also live in a rural area but I can't see that being the reason as the majority of people I have spoken to locally, have got their internet back up and running.
So plusnet please update your service status page to say that there are still ongoing issues.. please!
- « Previous
- 1
- 2
- Next »
