Broadband keeps dropping out
KGreig
My router drops out every 20 to 23 minutes right through the day, I've tried a reset and a factory re-set and I have stripped out my anti-virus and an mot running a VPN. Please advise, thanks.
16 REPLIES 16
Legend
Fixes: 255
Re: Broadband keeps dropping out
Welcome to the forums, @KGreig . If you would like help from the community, it would be a good idea to follow this guide: https://community.plus.net/t5/ADSL-Broadband/ADSL-Speed-faults/m-p/1270245#M297501 , reporting back with as much of the requested information as possible. A 'Quiet Line Test' - dial 17070 from a landline, preferably corded, phone and select option 2 - could also help.
Legend
Fixes: 255
Edit to add: There should be no noise on the line - if there is, report a phone fault to whoever you pay for your phone service.
KGreig
Thanks for the guidance @jab1 I shall do.
Alex
Fixes: 13
Yep @KGreig
Also remove anything else from your line, I am thinking to rule out extensions or dodgy equipment, etc. causing you the issue. Ideally just test your master socket. Though I appreciate it isn't easy.
KGreig
Thanks @Alex, I've followed the guidance and am only working with the main socket, my last ditch attempt is to also remove the phone line (which was lightly crackly on the line test) Plusnet also supply my line rental too so I'll look for a professional line test next.
Alex
Fixes: 13
PlusNet staff can post a Radius log graph (I believe) which will show them your disconnects.
Also I would disconnect everything you can and if you have a corded phone try a 17070 option 2 quiet line test. That will tell you if there is any noise on your line. If there is, then that may be your problem.
KGreig
Thanks for the support, there was nothing else to disconnect and last night the quiet test had a fair bit of background fuzz, so I'll be looking for tech support once home tonight.
Legend
Fixes: 255
In that case, run through the phone help page before you try and contact them - if there is a phone fault, completeing that may raise a report without you having to ring them.https://www.plus.net/help/phone/
Alex
Fixes: 13
Yep, as you're hearing noise, sounds like you may have a landline fault - so you'll need to raise it.
This has happened to me before.
KGreig
Thanks you for the advice and link, I'll come back and mark this fixed... hopefully within 3 working days, great progress.
Legend
Fixes: 255
Keep us updated - but hopefully that will solve it.
KGreig
Unfortunately my line is still "noisey" and the new "Unlimited Fibre Extra" account that I signed up to a fortnight ago in an attempt to throw my own trust and cash at the issue has proved folly.
I am no further forward as I still have a dropping connection and I'm now back in an 18 month contract to boot ☹️
The image is the result of the line test today that is a replicant of the "three day fix" from a fortnight ago:
Legend
Fixes: 255
Sorry to hear that @KGreig , but unfortunately these things do happen - it depends a lot on the problem and the ability of the engineers to fix it.
No consolation to you, but I had a connectivity problem that took about 6 months and 3 engineer visits to sort - and all three meant I had to be at home as there was no 'remote fix' available.
KGreig
The engineer was working on the issue this afternoon and marked the job as complete two hours ago. My line is still dropping out and running another line test I still get a fault listed. It was a mistake of mine to trust in an upgrade and an 18th month contract, this is now my final shot at a fix request. I have to show to both my family and employers that I'm committed to fixing the issue - I thought I'd done that by taking the Unlimited Fibre Extra pack but this has just been problems and disappointment.
Here's the latest "three day fix" promise. That means that by Thursday I have a fix by swapping to a Sky package or a working "Unlimited Fibre Extra" account.
