Broadband is terribly slow
- Broadband is terribly slow
Re: Broadband is terribly slow
07-02-2014 9:07 PM
What should I do after the line reset, is there any necessary procedures, like resetting my router?
Thank you very much.
07-02-2014 9:20 PM
07-02-2014 9:35 PM
Uptime: 1 day, 6:22:40
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6.272
Data Transferred (Sent/Received) [GB/GB]: 1,16 / 1,99
Output Power (Up/Down) [dBm]: 11,9 / 19,9
Line Attenuation (Up/Down) [dB]: 22,0 / 35,5
SN Margin (Up/Down) [dB]: 26,0 / 5,1
Chipset Vendor ID (Local/Remote): BDCM / ALCB
Loss of Framing (Local/Remote): 71 / -
Loss of Signal (Local/Remote): 10 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1.753 / -
FEC Errors (Up/Down): 44 / 0
CRC Errors (Up/Down): 88 / 439
HEC Errors (Up/Down): -8 / 439 / 15.026
This is the BT Wholesale Test:
Download speed achieved during the test was - 0.31 Mbps
For your connection, the acceptable range of speeds is 0.05 Mbps-0.5 Mbps.
Additional Information:
Your DSL Connection Rate :5.89 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 0.5 Mbps
Here is the current line speed from the PlusNet website:
Estimated line speed:
Current line speed:
7.15 Mb
07-02-2014 10:00 PM
However you appear to be on 20CN and therefore your IP profile may take a couple of days before it picks up
Plusnet may be able to kick it into action.
As a check can you see what this says about your exchange and 21CN http://usertools.plus.net/exchanges/
However something is odd - the router reports your sync speed as 6.272kbps but the BT speedtest reports it as 5.89kbps
Which came first the speedtest or the router stats as if it was the router stats then can you check what the speed is now
If it was the speedtest than something is very wrong
07-02-2014 10:09 PM
Is it possible for Plusnet to kick it into action and how would I go about requesting this? I need the internet as soon as possible.
I apologise for being impatient and thank you for your help.
07-02-2014 10:11 PM
More to the point, these stats are from a resynch some 30+ hours ago PRIOR to the reported line issue resolution time. I suggest a router restart sometime mid Saturday morning - certainly not during the hours of darkness.
Can new stats be posted please after a day time resynch.
07-02-2014 10:15 PM
07-02-2014 10:58 PM
07-02-2014 10:59 PM
Quote from: drenai So post new stats tomorrow mid-morning, early afternoon?
And immediately after the restart.
07-02-2014 11:44 PM
Bandwidth (Up/Down) [kbps/kbps]: 448 / 5.888
Data Transferred (Sent/Received) [MB/MB]: 32,57 / 478,81
SN Margin (Up/Down) [dB]: 26,0 / 7,4
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Error Seconds (Local/Remote): 17 / -
FEC Errors (Up/Down): 1 / 0
CRC Errors (Up/Down): 1 / 70
HEC Errors (Up/Down): - / 70 / 1.702
I apologise for the delay, here are the requested stats from my router, done moments ago.
08-02-2014 12:06 AM
Error rate is a little more than might be expected, but it is night time. Lets see what a resynch in the morning gives.
08-02-2014 10:27 AM
08-02-2014 12:30 PM
Uptime: 0 days, 0:02:19
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7.968
Data Transferred (Sent/Received) [kB/kB]: 325,71 / 237,25
SN Margin (Up/Down) [dB]: 26,0 / 6,4
Error Seconds (Local/Remote): 56 / -
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 339
HEC Errors (Up/Down): - / 339 / 1.559
Is it good or bad? I don't really understand what's going on.
08-02-2014 12:34 PM
Now some other points
What does your exchange say about 21CN http://usertools.plus.net/exchanges/
What is the Current Line speed here https://portal.plus.net/my.html?action=data_transfer_speed
Please run the BT speedtest - this is the quick way to get the IP profiles http://www.speedtest.btwholesale.com/PerformanceTesterWS/diagnostics.do
08-02-2014 12:40 PM
Current line speed:
7.15 Mb
Download speed achieved during the test was - 0.41 Mbps
Your DSL Connection Rate :7.97 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
Strange that it says I have two different IP Profiles, is the BT one wrong? Also the acceptable range seems a little slow, I have gotten around 4MB download before.
