Broadband dropping off
- Broadband dropping off
07-09-2018 7:19 PM
Re: Broadband dropping off
07-09-2018 7:30 PM
At least you've got internet connection, I've been waitng 17 days.....
07-09-2018 9:57 PM
Has this just started and have you connected the router directly to the master socket at the demarcation point? How frequently does it happen? DSL often retrains to obtain a stable service which will cause the PPPoE session to drop and re-establish.
Check / replace microfilter but also check the phone line to see if it's noisy. There could be a low signal-to-noise ratio but it's likely only PN staff will be able to interrogate the logs from the line.
07-09-2018 11:40 PM
08-09-2018 11:00 AM - edited 08-09-2018 11:01 AM
Hi @Teresa2,
I'm sorry that you're experiencing connection drops. I can see from your connection log that it's been dropping frequently over the past few days:
However testing your line isn't picking up the cause of this problem.
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 76.3 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Estimated Line Length In Metres | 637.8 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2018-08-26T11:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 19.0 Mbps | 79.9 Mbps | 77.0 Mbps |
Up Stream Line Rate | 16.5 Mbps | 20.0 Mbps | 19.9 Mbps |
Up Time | 360.0 Sec | 900.0 Sec | 894.4 Sec |
Retrains | 0.0 | 16.0 | 0.1 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-09-08T09:28:34Z | 2018-09-08T09:43:34Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Please can you run through our troubleshooting guides here. If the issue persists once you've done the troubleshooting checks, please report it here and let us know when you've completed it - we'll then be able to progress this further for you.
