Broadband dropped out 4 times
- Re: Broadband dropped out 4 times
22-01-2013 10:53 PM
My broadband has dropped out 4 times tonight.
I have reconnected but my speed is a quarter of what it was
It was 5.5 and is now 2
Tested on speed test website
I had the new technicolor router last week and it has been fine up until tonight.
Any ideas ?
Any ideas ?
Message 1 of 8
(2,013 Views)
7 REPLIES 7
22-01-2013 11:11 PM
Message 2 of 8
(679 Views)
23-01-2013 11:28 AM
Hi beaky32,
I've checked your connection and it's still syncing at the same rate as it has been. Are you connecting wired or wireless?
@Velocity, Are you using a wired or wireless connection?
Message 3 of 8
(679 Views)
23-01-2013 12:39 PM
I am connected through homeplugs hardwired to my router ?
My laptop is connected wirelessly.
Speed was great before but has disconnected 4 times last night, also keep sgoing back to login screen of router which tells me that the password I am entering is wrong ?
It played up all last night .
BTW I would kill for the speeds above..lucky so and so....Will Fibre ever make it to our little village in Wales I wonder ?
Once again thanks for your help !!
Message 4 of 8
(679 Views)
23-01-2013 1:00 PM
Are you getting the same speeds through a wireless and hardwired connection?
Message 5 of 8
(679 Views)
23-01-2013 7:48 PM
Seems to be back to 6 meg now...and no dropout today !!
Will keep an eye on it !!
Thanks for your help so far
Message 6 of 8
(679 Views)
24-01-2013 11:11 AM
No worries, let us know if anything changes.
Message 7 of 8
(679 Views)
24-01-2013 11:26 PM
Quote from: chrispurvey Hi beaky32,
Was using wireless, but have now sorted the problem with a LAN connection, so I am wired now
thanks
Message 8 of 8
(679 Views)
