Broadband dropouts
- Broadband dropouts
Re: Broadband dropouts
24-12-2015 9:27 AM
Quote from: Mardler Another OR engineer came out this morning. The fault was still there. He found a bad connection which helped but then found that we were on a "spare" line to the exchange that was unbalanced; he set up a totally new connection and all this dropped the line resistance to 2ohm of spec instead of several hundred.
The fault is no longer showing on OR diagnostics.
24-12-2015 9:29 AM
Quote from: Mardler PN, please note and act accordingly.
PN: please reset my profile.
Mardler is asking for an SNR Reset if one of the CRT could oblige
24-12-2015 9:47 AM
Having said this, when testing the connection to see if the reset would be appropriate right now, it did still fail the copper line test:
Quote The Copper Line test has failed. MFL :- (CE)
Resolution/Recommendation: BTW cannot progress this fault as the root cause is the PSTN failure. Please report to your Copper Line Service Provider.
With this in mind, it may seem that your fault has not been fully cleared and you might need to go back to your phone provider for further investigation if it does drop again.
If it does drop back down again, please let us know so we can test again anyway though and see if it's still returning the same results.
24-12-2015 9:58 AM
24-12-2015 10:09 AM
@Mardler
Was it the Master socket - NTE5a - that was replaced? Have you got anything different plugged in (or unplugged/disconnected) that wasn't previously?
Are you currently plugged in at the Test Socket, or the Master Socket front plate, or a fixed extension socket?
Do all your Microfilters look similar to this?
The 582n stats could be helpful as they may throw up something that could give a clue.
24-12-2015 10:49 AM
Townman - I agree.
Anotherone -
1. The master socket was replaced.
2. Nothing different is plugged in.
3. Router is connected to a fixed extension socket. BT tested internal lines.
4. Micro filter looks very similar and was checked by BT.
All - the last engineer tested the line as fault free at the box where the line enters the house but on the outside end, testing here before his work showed the fault and none after. However, he did one test with the inner end connected and he detected something odd so removed the filter & the fault (not the original) sometimes remained; that was when he again tested on the incoming line. The fault always showed up as >100m back to the exchange. He was certain the fault(s) had been fixed.
Interestingly, the third guy also said the first two got it wrong when they said the fault was at the exchange: he said what they were seeing was the broadband gear which explains why no fault was found testing from the exchange to the premises. Third engineer had totally different test kit: much more sophisticated.
Thanks all and Merry Christmas!
24-12-2015 11:13 AM
The line may have been testing fine when the engineer was there and something else could have happened in the past few days for all I know. For what it's worth the (CE) result in my previous quote indicates that the problem is being found on the customer end between the DP and the customer apparatus.
Hopefully it's just a false positive and the line is actually fine, at least over Christmas.
Merry Christmas!
24-12-2015 11:32 AM
Customer end doesn't sound good.
24-12-2015 3:02 PM
24-12-2015 3:11 PM
If it was finding something it believed to be past the test socket (i.e. In your house) it would return CA (Customer Apparatus) however having said this, CE does sometimes end up requiring an engineer visit to the property if the engineer is unable to find anything external between the property and the DP.
08-01-2016 8:36 PM
Above: "The line seems to be testing at around 18Mbps sync now"
Rubbish.
Just back from vacation and d/l speed is now 9mbps according to speedtest.net and 13.69 accotding to BT Wholesale.
IP Profile is set at 15.62.
08-01-2016 9:40 PM
What's your Current Line speed at present (Login required).
08-01-2016 11:36 PM
My point is that PN said sync was at 18.
A very close neighbour gets 19.
09-01-2016 12:07 AM
09-01-2016 6:28 AM
If you do a copy and paste (no need to grab it as an image) of the full page of stats (including the uptime) in a post then we might be able to make some more informed comment.
Quote from: Mardler My point is that PN said sync was at 18.
Your exact sync speed will depend on many factors, but the primary influence is the line. No two lines are likely to be identical - unless it happened to be brand new cabling all the way to the exchange! Other factors will be things like the modem/router & filters (different ones can give slightly different results), internal wiring and connecting cables, and any local electrical/electronic interference.
Plusnet's remark about sync speed was before Xmas. The speed may be different now. Posting the full stats as mentioned will be helpful.
To be crystal clear, there is nothing Plusnet (or any ISP) do/or can do that can alter the state of the line to the exchange. If there is still a fault on the line, that could still be having an effect. What happened about this reported CE fault?
