Broadband a/c queries
- Re: Broadband a/c queries
04-04-2008 11:26 AM
I am selling my house and probably moving into rented in a different area. Couple of questions please --
1) Will I have any problem opening (or transferring) a broadband a/c as a tenant rather than houseowner (I've been with plusnet about 4 years)
2) Will I be committed to 12 months? (I may move again at 6 months)
3) Will I be able to use BT call diversion (network services) on the same phone line as the broadband, or will I have to get a 2nd landline? (I currently I have 2 separate phone lines).
Message 1 of 4
(986 Views)
3 REPLIES 3
04-04-2008 11:35 AM
1) Transferring the account to your new address won't be a problem.
https://portal.plus.net/my.html?s=0&action=adsl_reprovision
2) You'll be deferring the activation fee of £40. If you move house again within the next 12 months, we would need to charge you £40 to do so. Also if you were to cancel within 12 months of moving, we would need to charge you £40. This is because BT Wholesale charge us £40 to provide a broadband service
3) There's no reason why this wouldn't work on the same line as the broadband one.
Message 2 of 4
(372 Views)
04-04-2008 11:55 AM
Just to add a bit of info that may be useful given you have 2 lines and so presumably 2 numbers at present.
I use BT's Call Sign service combined with a couple of TwinTalk adapters to have 2 numbers on one line (personal and business) going to different phones in different locations in the house. This works fine with Broadband.
(Obviously there's only 1 outgoing number and you can only be in 1 call at a time)
Message 3 of 4
(372 Views)
04-04-2008 11:54 PM
Many thanks guys, should work quite smoothly then hopefully.
Message 4 of 4
(372 Views)
