Broadband Your Way
- Re: Broadband Your Way
Broadband Your Way
06-08-2007 8:52 PM
Hi all
I'm currently on Metronet PayGo and want to move to Plusnet Broadband Your Way. Two questions:
- Surely there must be a way of doing this that isn't as complicated as moving between two unrelated ISPs?
- I seem to currently have a static IP address. Will I be able to select dynamic after the move?
Dan
Message 1 of 8
(2,421 Views)
7 REPLIES 7
06-08-2007 8:56 PM
Quote - Surely there must be a way of doing this that isn't as complicated as moving between two unrelated ISPs?
Well... they are related, but I see your point. Unfortunately as yet we haven't implemented an easy transfer, though it is free and shouldn't take more than a day - if you create a new pay-as-you-go dialup account on the plusnet site, then create a ticket on there referencing your metronet username (and a corresponding ticket on your metronet account) we'll place the modify order and advise when your new acount is ready to connect to. There'll be no loss of service from your point of view.
Quote - I seem to currently have a static IP address. Will I be able to select dynamic after the move?
Absolutely, in fact the BBYW accounts have a dynamic IP by default.
Hope this helps,
Message 2 of 8
(720 Views)
06-08-2007 9:05 PM
Quote from: orbrey Unfortunately as yet we haven't implemented an easy transfer, though it is free and shouldn't take more than a day - if you create a new pay-as-you-go dialup account on the plusnet site, then create a ticket on there referencing your metronet username (and a corresponding ticket on your metronet account) we'll place the modify order and advise when your new acount is ready to connect to. There'll be no loss of service from your point of view.
Excellent, thanks for your superfast response. Ideally I was hoping that there would be an "upgrade" button hidden somewhere, but I'm sure I can follow the instructions you've given
At least I don't have to get a MAC from Metronet to give to Plusnet!
Thanks again
Dan
Message 3 of 8
(720 Views)
07-08-2007 9:52 AM
Actually, having said that. It's probably easier to do it by placing an order on the PlusNet website and by getting a MAC Key (which I can help you out with).
Migrations are currently free.
http://www.plus.net/switch
Message 4 of 8
(720 Views)
07-08-2007 1:07 PM
Quote from: James Actually, having said that. It's probably easier to do it by placing an order on the PlusNet website and by getting a MAC Key (which I can help you out with).
Will do. Could you e-mail me a MAC key please?
Message 5 of 8
(720 Views)
07-08-2007 1:09 PM
If you raise a ticket on your account, I will be more than happy to do so.
https://portal.metronet.co.uk/contact_us.html is your friend.
Message 6 of 8
(720 Views)
07-08-2007 1:16 PM
Doing it now. Cheers.
Message 7 of 8
(720 Views)
07-08-2007 2:02 PM
Just replied to your ticket. You should see your MAC Code now, which you'll be able to use when placing an order with us.
Message 8 of 8
(720 Views)
