Broadband Usage (Fault)?
- Broadband Usage (Fault)?
02-03-2011 7:28 PM
I have an outstanding fault query waiting to be fixed so if I switch off the router for 24 hours I will have to start all over again with that fault and of course I don't like being off line for 24 hours!!!
Any suggustions?
Thanks for any help
Re: Broadband Usage (Fault)?
03-03-2011 9:39 AM
03-03-2011 9:45 AM
dick:quote
03-03-2011 9:53 AM
03-03-2011 10:02 AM
dick:quote
03-03-2011 10:05 AM
Did they tell you the times of the large downloads? If not try asking, it would confirm if the download was when the PC was hibernated.
03-03-2011 10:11 AM
They said that was all they could do until it was confirmed the router was bad.
[Moderator's note by Dick (Strat): Full quote of preceding post removed, as per Forum Rules ]
Please use the 'Reply' button rather than the 'Quote' button when replying to the last post.
03-03-2011 10:54 AM
Below is hour by hour for the day in question.
[quote=26th February]
These figures are in MB...
Hr up Down
0 32.2694 1099.9017
1 15.1414 393.0963
2 0.0197 0.2178
3 0.0042 0.0306
4 0.0042 0.0052
5 0.0041 0.0062
6 0.0041 0.0055
7 0.0031 0.0067
8 1.4791 3.0911
9 6.7062 184.6443
10 11.9688 348.8674
11 5.5577 71.9088
12 7.2329 239.4426
13 8.2937 216.1464
14 1.0108 17.4889
15 5.9258 96.3190
16 9.9244 167.3288
17 8.9417 128.7339
18 7.1927 99.0275
19 0.2055 0.9153
20 0.0042 0.0055
21 0.0041 0.0058
22 1.5851 2.9866
23 10.8256 105.8951
Hope that helps.
Jojo
03-03-2011 11:11 AM
I can discount the up/down between hrs o and 8 and that is where my problem starts. I left the house at about 10:30 or 11:00 a.m. and didn't come back until after 6p.m. and you can see that the up and down reverts back to somewhat normal amounts. I am just perplexed as to how the figures between 10 and 6 got there!
I always put the pc on hibernate when I go out and I live alone (sad) but I can't PROVE that I did not use my computer at those times, so I will have to accept it and just watch I don't go over my usage this month. Losing 1.77GB in one day is a hell of a lot. As you can see, I always do my large downloads after midnight. Oh well, nothing I can do about it!!
Thanks for the help Jojo and jelv
jim:quote
03-03-2011 11:29 AM
forgive me for maybe asking a silly question... As it was a Saturday, would anyone else have been using the computer while you were out?
Jojo
03-03-2011 12:48 PM
jim:quote
03-03-2011 2:00 PM
Quote from: mexicano I have a wired connection using a Thomson 560 router which has already been replaced once!!
What happened to the old router?
B.
03-03-2011 3:33 PM
If you have given your old router to someone else you need to change the password on your Plusnet account and then change the connection password on your router to match.
03-03-2011 4:12 PM
jim:quote
03-03-2011 4:27 PM
You mentioned before that an agent had told you to switch your router off for 24 hours but 7 or 8 would do so if you go out for the day like last time then maybe switch your router off then and see what happens.
Jojo
