Broadband Speeds Up and down while downloading..
brownyy
I have contacted the technical team over the phone and they cannot seem to find a problem. What happens is when i download anything the speeds will go up to 1.5MB/s and then go down to 1kb/s continuously. My internet connection is not stable at all. Also if I use Youtube the videos wont always load etc. Also ever since i have had the phonecall my IP profile has gone down to 7MB from 18MB !?
10 REPLIES 10
jelv
Fixes: 10
Re: Broadband Speeds Up and down while downloading..
How do you connect to the router, wired or wireless?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
brownyy
Now my profile has gone up? Why does it keep changing? I am connected wired straight to the router. The connection just wont give a stable speed when downloading.
adamwalker
Fixes: 221
It looks like we're seen the connection drop quite frequently over the last couple of days, have you been rebooting the router at all?
Adam
 Adam Walker
brownyy
Yes i have rebooted my router several times. I have also just started the ping test with thinkbroadband and there is some red spikes already?
brownyy
Then i got cut off so having to re-start the test.... (new IP)
adamwalker
Fixes: 221
Thanks brownyy,
I'd avoid rebooting as that will eventually have a negative impact on speeds too. I can see you've raised a fault so our faults team will investigate and get back to you ASAP.
Adam
 Adam Walker
brownyy
I have been trying to raise a fault but the page wont load? how can i access the ticket because i have not been able to put any information in?
chrispurvey
A fault ticket was raised earlier, I can see you've added notes to this too. Our faults team will update you once they've checked over things.
brownyy
Why is there a constant yellow spikes even some red? I was not even using the internet through the night?
chrispurvey
The red is either when you're not connected or you've changed IP address, the latter seeming to be the case here when you've reconnected.
Has you connection improved? Our faults team will be picking your ticket up shortly.
