Broadband Speed Issues :: 24-11-09 :: Discussion
- Broadband Speed Issues :: 24-11-09 :: Discussion
24-11-2009 8:42 PM
If you are considering posting a speed issue thread, please read the above service status.
If you believe your issue is not related, then feel free to create a new thread about your issue.
If you believe that your issue is related, please keep your discussion about the issue in this thread.
Many thanks
B.
Re: Broadband Speed Issues :: 24-11-09 :: Discussion
24-11-2009 10:09 PM
I'll desticky this topic after some more feedback, if necessary.
B.
24-11-2009 10:41 PM
Date Download Speed Upload Speed
Today 22:37 909 kbps (114kB/s) 358 kbps (44.8kB/s)
Today 22:30 871 kbps (109kB/s) 349 kbps (43.6kB/s)
Today 21:41 595 kbps (74.4kB/s) 355 kbps (44.4kB/s)
Of course.... there are two possible reasons for the increase to "normal" speed......
1. Everyone has logged off and gone to bed because of lousy speeds.
2. someone has managed to fix the machine !
24-11-2009 10:43 PM
As per Tommo's post the latter is the case.
suppose thats one of the problems with multiple threads on the same subject. It's hard to know which one to update.
24-11-2009 10:50 PM
24-11-2009 10:52 PM
Have you run thru the usual speed fault scenarios and raised it to us?
24-11-2009 10:57 PM
You may remember me from yesterday, "@abomb1969, as long as you remain synchronised at 3584kbps your IP profile and download speed should follow suit before too long."
My IP profile is still 135kbps and its been over 24 hours since I replaced my modem. BT speedtester just reported 100k d/l. Soooooo slow!
Cheers
Craig
24-11-2009 11:40 PM
Cheers
B.
24-11-2009 11:50 PM
This connected me to gateway thn-ag1, it is also noticeable that my horrendous PING times (200ms to 960ms) is back down to a more normal 54ms.
25-11-2009 12:08 AM
Quote from: abomb1969 My IP profile is still 135kbps and its been over 24 hours since I replaced my modem.
How long does your router say it has been connected?
25-11-2009 6:56 AM
25-11-2009 7:28 AM
Quote from: Mark Possibly unrelated issue pacamack.
Has your router been continually connected at a higher sync speed?
25-11-2009 8:56 AM
And Xmas is coming, which could be a bad time for the PN network to be in this state as people are taking time off work and their shopping online for presents.
SW.
3Mb FTTC
