Broadband Speed Issues - 03/10/09
- Broadband Speed Issues - 03/10/09
03-10-2009 6:25 PM
So, if you are having problems with peak-time speeds, can I ask you to read the following, and submit a reply answering as many of the questions as possible.
1. Your product type
This information can be found here. For example, mine is:
"PlusNet Broadband Your Way Pro with included 15GB bandwidth"
Please include if you are on the ADSL2+ Trial.
2. Your current usage from the VMBU
The "View My Broadband Usage" tool will show you exactly how much you have used in the current billing month. You can access the VMBU tool here. Please post your current usage similar to the following:
Paid-for usage 11.22GB 8am - Midnight
Paid-for allowance: Up-to 15GB 8am - Midnight
Free usage: 55.62GB Midnight - 8am
Total usage: 66.84GB
3. Your IP Profile, as reported by Plusnet
You can access this information here. Please copy/paste the information like this:
"Your current broadband speed is 7150 Kbps"
4. Information from the BT Speedtester
Please run the BT Speedtester and post the results in the following format:
Your DSL connection rate: 8128 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 7150 kbps
Actual IP throughput achieved during the test was - 6252 kbps
5. A Speedtest from an external testing site.
Please try to do an external speedtest. I recommend using This one. Post the results including the date and time of the speedtest. If there are particular times when you connection is "bad", please try to post a comparative speedtest from when your connection is "good".
6. Your gateway
If you visit this link and please post the results:
"You are currently connected to the "City Lifeline, Juniper 8" gateway. This gateway is sometimes known as pcl-ag01."
7. Your exchange status
Go to the Exchange checker and post the "VP Status" of your exchange:
"VP capacity at this exchange is currently showing as Green."
8. Any other information
Please include any other information that you think may be pertinent. Please keep it brief and to the point. If we can collate together as much information as possible then it should assist Plusnet in identifying a common cause and resolving the issue once and for all.
I have included a template post below, which you can quote from and then fill in.
Please note that any posts that are not in this format are likely to be split off, or removed without warning
B.
Re: Broadband Speed Issues - 03/10/09
03-10-2009 6:26 PM
6. Your gateway
03-10-2009 6:26 PM
6. Your gateway
"Speeds are slow from exactly 4.00pm every day until 4.07pm, then speeds seem to return to normal."
03-10-2009 7:00 PM
Broadband Plus (legacy product)
Peak usage: 1.08GB
Off-peak usage: 580.87MB
Total usage: 1.66GB
6500
03/10/2009 18:49
Download speedachieved during the test was - 4629 Kbps
Additional Information:
Your DSL Connection Rate :7616 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
mybroadbandspeed.co.uk:
03/10/2009 18:46 264 kbps (33kB/s) 371 kbps (46.4kB/s)
6. Your gateway
lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
Green
Speeds can vary on the external tester from as low as 80kbps to as high as 6000+
I see the lowest speeds between 17:00 and 21:00 but I am really only able to monitor them between those times
Low speeds are accompanied by noticeably slow browsing, partial pageloads and so on
Pings and tracerts seem nornal for my line during this time
BT tester is consistently between 5000-6000 during slowdowns.
My expected speeds are 5000-6000 on this line.
Stats at 18:57 03/10/09:
sync: 7616000
SNR Margin 15.5
Loop Att.9.0
Interleave ON
04-10-2009 1:35 PM
BBYW Option 1 with 10GB Bandwidth
1.35GB
7150
Download speedachieved during the test was - 1169 Kbps
Your DSL Connection Rate :8218 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
Range from mybroadband speed.co.uk
Down Up Date Time
611 382 19/09/2009 15:49
6667 382 22/09/2009 10:08
6. Your gateway
ptn-ag1
Green
Line attenuation 6dB
SNR 8.4dB
Interleave: On
The dial during the mybroadbandspeed test fluctuates wildly. Notably when the download speed is high the upload drops suggesting high usage by others. Sometimes whilst the speed may be showing high the test takes an age to complete. Presumably because of interleaving.
This is a recent problem. I used to get a consistent 4500-5000kbps connection.
04-10-2009 4:56 PM
PlusNet Broadband Pay As You Go with included 2GB bandwidth
£15.99 a month
Paid for usage 52.81 MB 8am to midnight
Paid for allowance Up to 2GB 8am to midnight
Free usage 29.16MB midnight to 8am
Total usage 81.97MB
Current line speed 750
Download speed 518Kbps
For your connection the acceptable range of speeds is 200-1,000 Kbps
Your DSL connection rate is 896Kbps Downstream / 448 Kbps Upstream
IP Profile for your line is 750 Kbps
From mybroadbandspeed.co.uk, on Sunday 4 October 2009 at 16h35
Download speed 659 kbps
6. Your gateway
"Telehouse North, Juniper 5" gateway. This gateway is sometimes known as thn-ag2
Green
Connection speed is abysmal almost all the time. Very rare to get through to a page on first click, even at 4am; I am much more likely to see the dreaded "Internet Explorer cannot display..." after 45 seconds or more of waiting.
04-10-2009 5:36 PM
PlusNet Broadband Plus up to 8Mb
Peak usage: 4.51GB
Off-peak usage: 1.13GB
Total usage: 5.63GB
Not recorded (service activated before we introduced estimates).
Current line speed:
5000
Download speedachieved during the test was - 4075 Kbps
Your DSL Connection Rate :5760 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 5000 Kbps
www.mybroadbandspeed.co.uk on 04/10/2009 @ 17:27 - Download speed 105kbps upload 88 kbps
6. Your gateway
City Lifeline, Juniper 9" gateway. This gateway is sometimes known as pcl-ag022
In the evenings and weekends connection is worse than useless. Seems to be ok during the day. We use Skype to keep in touch with relatives but its been unuseable for almost 2 weeks now - they can hear us fine though which suggests upload is ok.
04-10-2009 9:52 PM
PlusNet Broadband Premier ( Legacy / BT Max Premium Upto 832kb\s Upload)
Peak usage: 7.46GB
Off-peak usage: 175.36GB
Total usage: 182.82GB
Estimated line speed:
Current line speed: 7150
Download speedachieved during the test was - 4479 Kbps
For your connection, the acceptable range of speeds is 1200-7150 Kbps.
Your DSL Connection Rate :6304 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
6. Your gateway
You are currently connected to the "Telehouse North, Juniper 6" gateway. This gateway is sometimes known as thn-ag1.
lo0.plusnet.thn-ag1.plus.net
Exchange: Vauxhall
Constant Random Disconnections, lower Download/Upload Speeds any time (peak & off-peak) , normally download at 800kbs and upload at 88kbs but much lower speeds. Continuously have to reboot router, so it connects to the server. Tested connection on 2 other Pcs (To rule out hardware defects) with other Routers and different settings (Lowered MTU to 1450 and 1400 and set to default) same occurance.
Details as of this connection are Downstream & Upstream Respectively
SNR Margin (dB) : 6.1 7.0
Attenuation (dB) : 36.0 23.0
04-10-2009 10:37 PM
2) Peak usage 265.93 MB
Off Peak Usage 1.01 MB
Total Usage 266.94 MB
3) Current Line Speed 7000 kbps
4) Download speedachieved during the test was - 2 Kbps
Your DSL Connection Rate :1000 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7000 Kbps
5) Download 84 kbps
Upload 386 kbps
6) "You are currently connected to the "City Lifeline, Juniper 8" gateway. This gateway is sometimes known as pcl-ag01."
7) Exchange - Burton
8 ) Speed has been continuously poor for approximately the last ten days at least.
05-10-2009 9:05 AM
05-10-2009 9:06 PM
Force9 Broadband Plus up to 8Mb
Peak: 423MB
Off Peak: 2.78GB
Total: 2.78GB
Current line speed: 6000
Download speedachieved during the test was - 4646 Kbps
Your DSL Connection Rate :7360 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6000 Kbps
www.mybroadbandspeed.co.uk/
Downlload Speed: 81kbps Upload Speed 67kpbs
Test done at 20:50 strait after BT speed test
6. Your gateway
You are currently connected to the "Telehouse North, Juniper 7" gateway. This gateway is sometimes known as thn-ag3
Code: SDWWST
This problems occurs almost every evening with this evening being a particularly bad one. Sometimes the speed will return to normal for a short period.
The speed is almost aways good (around 5Mbps) in the morning.
Edit: Speed is now back up to
06-10-2009 8:07 PM
Quote from: Barry 1. Your product type
Force9 Broadband Premier Option 1
Peak 3.91GB
Off Peak 7.03GB
Total Usage 10.94GB
6500
Download speedachieved during the test was - 3926 Kbps
Your DSL Connection Rate :7776 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
Today 20:04
2127 kbps (266kB/s)
369 kbps (46.1kB/s)
6. Your gateway
You are currently connected to the "Telehouse North, Juniper 1" gateway. This gateway is sometimes known as ptn-ag1.
VP Status is currently showing as Green
I was round at my mums house last night who is on the same exchange and on F9/Plusnet and it was going incredibly slow when downloading Java from java.com (always a fast download)
06-10-2009 8:49 PM
PlusNet Broadband Your Way Option 2 with included 15GB bandwidth
Paid-for usage 1.81GB 8am - Midnight
Free usage: 975.34KB Midnight - 8am
Total usage: 1.81GB
Current line speed:
2500
Test failed
6. Your gateway
You are currently connected to the "City Lifeline, Juniper 9" gateway. This gateway is sometimes known as pcl-ag02.
Sourceforge seems to be the most affected site - download from there sat around 12kb/s whilst a later download from elsewhere stayed around the 150kb/s
06-10-2009 9:04 PM
Madasafish 2 Mbps i.e. 2272kbps Down .... 288kbps Up
MAAF My Account usage
This month: 552.32MB
Monthly usage 5GB
Test result 1818 kbps, no IP profile with fixed speed connection
http://www.mybroadbandspeed.co.uk/results/05301991.png
6. Your gateway
2 33 ms 34 ms 32 ms lo1.ptn-ag03.plus.net [195.166.128.43]
Virtual paths: Green
Started getting worse after 7.45pm
http://www.mybroadbandspeed.co.uk/results/05301308.png
It's dry for a change, 8*C and a fullish moon
Edit >>> 10.12 pm ..... speedtest result:- http://www.mybroadbandspeed.co.uk/results/05304027.png
and at 10.24 pm ..... http://www.mybroadbandspeed.co.uk/results/05304216.png
08-10-2009 5:03 PM
Paid for usage 3.57GB 8am to midnight
Paid for allowance Up to 15GB 8am to midnight
Free usage 3.38GB midnight to 8am
Total usage 6.95GB
Current line speed 6500
Download speedachieved during the test was - 1629 Kbps
6. Your gateway
You are currently connected to the "City Lifeline, Juniper 11" gateway. This gateway is sometimes known as pcl-ag04.
Green
No matter the time of day or night the speed is so variable that it's a joke. One minute it can be flying along at my normal speed of :-
Yet a few seconds later it can drop to unusable speeds, this even occurs in the wee small hours too.
