Broadband Products
- Re: Broadband Products
Broadband Products
16-01-2008 3:05 PM
Hi, I could do with some advise please. I currently have a legacy broadband product (Broadband plus 8mb) which offers me a reasonable speed, though no where near 8mb :(, and off peak access between midnight and 1600hrs which is when I mostly use the internet.
What are the benefits for me to move to a BBYW product as the off-peak access is only from midnight to 0800?
Message 1 of 3
(791 Views)
2 REPLIES 2
16-01-2008 3:08 PM
There are two things that you have to consider really. How much you use and when you use it. If you use 8GB or less between 0800-2400 then Option 2 is ideal, if not then you're on the best product for you.
I've had a look at your current usage and would have to say that you're probably already on the ideal product and there should be no reason to change.
Message 2 of 3
(268 Views)
16-01-2008 3:14 PM
Thanks James, I appreciate the speedy response.
I thought I was on the right product but it was worth checking.
Message 3 of 3
(268 Views)
