Broadband Pro Speeds...
- Broadband Pro Speeds...
16-12-2007 10:57 PM
The BT BRAS profile shows 4000k as does the plusnet,
IP profile for your line is - 4000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 4704 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 2728 kbps
Your High-speed Broadband Service
Your current broadband speed is 4000 Kbps
This is confirmed with the Plusnet Speedtest...
Date Download Speed Upload Speed
Today 22:50 2445 kbps (306kB/s) 371 kbps (46.4kB/s)
Are there any network speed issues currently, thought Pro was supposed to be at line speed?
Cheers
Cheers
Message 1 of 5
(1,124 Views)
4 REPLIES 4
Re: Broadband Pro Speeds...
16-12-2007 11:06 PM
Have you optimised your MTU etc?
Assuming you are on a router, do you connect wired or wireless?
It could be exchange contention (Plusnet has no control over that)
Does the PN Platinum, Gold, Silver affect the BT speedtest? I thought it would bypass that. I would have thought results from something like http://www.mybroadbandspeed.co.uk/ would be more relevant.
Message 2 of 5
(476 Views)
16-12-2007 11:12 PM
Thanks Jelv, of course... I've not been fault finding on broadband for a while. The BT speed test confirms that this is exchange side!
MTU default at 1400, will increase and post results. I'm on a router with wireless, tested wired and no difference.
Speedtest should circumvent traffic prioritisation
Message 3 of 5
(476 Views)
16-12-2007 11:31 PM
Adjusted MTU from 1400 to 1500 and got an additional 500kbps on each test which is cool
If MTU is too high I'm guessing I will see some connection drops / packet errors increasing?
Message 4 of 5
(476 Views)
17-12-2007 12:00 AM
I can't think of any way a higher MTU could affect connection drops. I suppose that with bigger packets it is possible that you might be more likely to see errors - but if it is it is probably more than outweighed by the reduced number of packets required to transmit the data.
Message 5 of 5
(476 Views)
