Broadband Intermittent sometimes every 10secs
- Broadband Intermittent sometimes every 10secs
Re: Broadband Intermittent sometimes every 10secs
31-01-2018 11:07 PM
Look forward to seeing Gandalf's thoughts. I don't profess to understand all of the terminology. As previously expressed just confused by difference in TPL &PN thoughts re the SNR margin - at present line is far more stable than ever been -
31-01-2018 11:15 PM
@niallcampbell @RealAleMadrid Gandalf is now on an extended holiday on the other side of the planet, so don't expect an answer anytime soon.
@niallcampbell have you had a look on the DSL Checker to see what you could get?
03-02-2018 11:01 AM
wrote:
If the TPlink router stats are believable the OP is on extremely high SNRM values already (27db down 25dB up!)
I think a line reset would help a lot. Also is the line provisioned on ADSL_Max (G.DMT)? Is ADSL2+ not available, if it is the download speed should be over 20Mbps as it is a fairly short line (13dB Attenuation down).
Those stats are from the example in the TP-Link documentation, not the actual line in question.
03-02-2018 1:47 PM
Ah, sorry about that, thought they were the Op's stats, which we don't seem to have had any sight of. The information from TP Link has not been helpful to say the least, "please use another phone line" is a good one.
04-02-2018 1:27 PM
Hi.
I had a similar problem and also use a TPLink router. The log includes a lot of routine stuff but I found it useful to set a filter. On the System Log page, click on "Log Settings", at the next page at "minimum level" select "Warning" and save. Now the logs will only include significant details ignoring the routine house keeping stuff. If broadband drop outs are occurring, there will likely be messages with "PPP" in them. At least, that is what I was seeing on my Archer VR900.
Mick.
05-02-2018 11:24 PM
Thanks will change it and see. Just had a series of non connections this evening.
06-02-2018 3:45 PM
This has been happening more frequently since yesterday
ID | Time | Type | Level | Log Content |
1 | 2018-02-05 23:06:04 | SYSTEM | Notice | LAN2 link up 1000 mbps |
2 | 2018-02-05 23:06:00 | SYSTEM | Notice | LAN2 link down |
3 | 2018-02-05 22:38:17 | SYSTEM | Notice | LAN2 link up 100 mbps |
4 | 2018-02-05 22:38:14 | SYSTEM | Notice | LAN2 link down |
5 | 2018-02-05 22:37:23 | SYSTEM | Notice | LAN2 link up 1000 mbps |
6 | 2018-02-05 22:37:20 | SYSTEM | Notice | LAN2 link down |
7 | 2018-02-05 22:04:48 | SYSTEM | Notice | LAN2 link up 100 mbps |
8 | 2018-02-05 22:04:45 | SYSTEM | Notice | LAN2 link down |
06-02-2018 5:44 PM
06-02-2018 5:57 PM
It coincides with wifi dropping too - which has been happening frequently since yesterday. Nothing else plugged into Lan ports.
Just trying to understand everything - I clearly don't. I am considering using different DNS to see if issue happens on non PN dns.
07-02-2018 7:43 AM
This is what I have from last night
1 | 2018-02-06 22:32:22 | PPP | Warning | ppp0 LCP down |
2 | 2018-02-06 22:32:22 | PPP | Error | ppp0 LCP down |
3 | 2018-02-06 22:32:19 | PPP | Error | ppp0 |
4 | 2018-02-06 22:32:19 | PPP | Warning | ppp0 LCP down |
5 | 2018-02-06 22:32:19 | PPP | Error | ppp0 LCP down |
6 | 2018-02-06 22:32:19 | PPP | Error | ppp0 User request |
7 | 2018-02-06 22:20:14 | PPP | Warning | ppp0 LCP down |
8 | 2018-02-06 22:20:14 | PPP | Error | ppp0 LCP down |
14-02-2018 6:22 PM
Becoming quite depressed by this - just want a constant connection
14-02-2018 10:53 PM
Tonight has been dreadful! Connection - no connection constantly interruptions to online service - looking at going elsewhere
14-02-2018 11:10 PM
Hi
Way back in your thread you mentioned you use "wifi extenders". What make and models and are you still using these? HOw many are there? How old are they? If they are still connected can you try to do without them for a few days and then report back if you still have connection issues.
15-02-2018 6:59 AM
Hi run hare - This is happening using ethernet directly to my iMac - understand if it was just wifi but it is happening to hardwired connection
17-02-2018 10:30 PM
