Broadband Interferring with phone line? Help!!
- Broadband Interferring with phone line? Help!!
17-12-2009 9:03 AM
monday i came home and i had no phone or broadband and both were fine when i went out in the morning.
i called BT after checking the phone in the master socket and still all i had was a bit of noise but no phone and they said someone was checking it out.
after an hour or so i had my phone back and broadband all be it my profile had changed to 500 from 8128 on the bt speedtester but also had a hiss on the line.
BT phoned and said they need an engineer to gain access to the property to finish the repair
the BT guy called this morning and traced the hiss to when my router boots up and says the phone line is fine and look forward to the bill!!
i have a flitered face plate and we tried it with his filter and my original instead of the face plate and still the hiss comes back as soon as the router boots up.
can anyone tell me if this is my router thats at fault or could it be the broadband interferring some how, and could my router have caused me to lose my phone line.
i have attached a page from the router although the the 63 figure seems to be stuck as its always shown that even when james looked at it months ago he said it was to be disregarded and i have a screenshot from november and it said 63 then as well and speeds were fine, bit weird though
i gotta go to work now but any help would be very much appreciated
cheers
Re: Broadband Interferring with phone line? Help!!
17-12-2009 4:09 PM
17-12-2009 6:55 PM
but yes, the phone line hisses until i switch off the router and it immediately dissapears, switch it back on and its ok unitl it connects, ie all lights come on and it starts to hiss again.
Any ideas?
cheers
Andy
17-12-2009 8:00 PM
i have changed router to safecom router i had
changed pc to laptop
chaged filter for different one, as did Bt ' i only know two wires mate' engineer.
put laptop next to master socket with new cable from filter to router
changed lead from router to laptop
still hiss on the phone line that stops when the router is turned off, but there is still a faint to significant crackle on my phone line with the router unplugged and only a corded phone plugged into the master socket filter although we couldnt hear that this morning
what do think from here
many thanks
17-12-2009 8:13 PM
17-12-2009 8:30 PM
i tried it tonight with the filter in the master socket and the broadband cable and corded phone attached and the phone still hisses. as soon as i unplug the router cable from the filter the hiss stops but do i do still have an intermittent crackle which is quiet at times.
i have posted new router stats if that makes any sense.
many thanks
18-12-2009 7:39 PM
anyone got any bright ideas to speed things up a bit?
cheers
19-12-2009 1:35 PM
i logged into my router and viewed the stats page which updates every second to see what happens when i pick up the phone. i have attached pics below but basically D/S SNR margin without phone is betweeen 6.0 to 7.9, when i pick up phone and dial it goes to 10.4 - 12.2 and also connection dropped twice in a couple of minutes.
24-12-2009 11:44 AM
excellent guy, diagonsed the problem withing 30 seconds of arriving, confirmed it was an HR fault on the line using his hawk thing, within an hour and a half he was back and the line was repaired.
he says it was capable of supporting up to 9 meg connection and the speed on the line was 7900.
i will probably have to wait for it to catch up on my profile and i will need interleaving turned off after it was pointlessly turned on but hopefully will be all good from now on.
well thanks a bunch plusnet, your forum support and ticket support was prettty poor this time, lets hope its a one off as its usually first class
29-12-2009 4:28 PM
Glad to hear you got things sorted, but I'm sorry to hear that the support wasn't up to scratch.
I'll be reviewing your ticket history, and passing feedback on where necessary.
30-12-2009 10:31 PM
i must say that although i have only had minimal experience with the ticket system i dont have much faith in it and usually the forums have been excellent but i think this time it was purely a hardware fault outside everyones field.
thanks for coming back anyway
