Brief Disconnection
- Brief Disconnection
Brief Disconnection
25-10-2014 3:34 PM
About 3 hours ago I happened to have Routerstats fired up and noticed SES errors racking up quite quickly, far faster than normal.
I tried to access Plusnet status and it went from slow access to non-existent.
I tried a ping to bbc.co.uk as all router lights were ok and it was unreachable.
I therefore disconnected the PPP session, waited a couple of minutes and switched off the router.
I switched it back on after a little over an hour and all seems back to normal.
Edit:
Just looked at the TBB graphs and it seems to be just me
Edit:
Message 1 of 3
(588 Views)
2 REPLIES 2
Re: Brief Disconnection
25-10-2014 3:58 PM
Just you Strat?
Next you'll be believing "They're out to get you...".
Kevin
Kevin
Message 2 of 3
(396 Views)
25-10-2014 4:09 PM
No telecoms vans in the area so maybe an 'engineer' was fiddling about in the exchange.
Message 3 of 3
(396 Views)
