Brand new 21CN stats do these seem right?
- Brand new 21CN stats do these seem right?
16-08-2012 1:47 PM
Date of Stats 16/08/2012 13:36
Uptime: 0 days, 0:01:50
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 888 15892
Data Transferred (Sent/Received) [kB/kB]: 0.00 0.00
Output Power (Up/Down) [dBm]: 12.5 0.0
Line Attenuation (Up/Down) [dB]: 10.0 23.5
SN Margin (Up/Down) [dB]: 14.5 6.5
Vendor ID (Local/Remote): TMMB IFTN
Loss of Framing (Local/Remote): 11 0
Loss of Signal (Local/Remote): 2 0
Loss of Power (Local/Remote): 0 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 2 0
FEC Errors (Up/Down): 0 38
CRC Errors (Up/Down): 0 0
HEC Errors (Up/Down): 0 0
Re: Brand new 21CN stats do these seem right?
16-08-2012 1:54 PM
You are synching at a good speed which is a good start but it's too early in the training period to be able to predict exactly what parameters and performance it will settle down at.
16-08-2012 2:14 PM
16-08-2012 2:24 PM
16-08-2012 2:30 PM
16-08-2012 2:31 PM
Quote from: Oldjim I am surprised to see that your upstream is apparently interleaved
'tis the standard initial setting it seems
leave it alone for a few days and the DLM will probably reduce the interleaving depth (it will be at 8 currently) and free up the sync to run at whatever it can do at 6 margin target upstream (yr current upstream margin is 14)
D/S power reported as zero is a known router/DLAM bug present in many routers - the real value is around 19dB.
If you are lucky after some 4 days the DLM might reduce the target SNR margin downstream to 3 if the line is good.
16-08-2012 2:36 PM
I have no idea what each of these things really mean nor what sort of values to expect and what impact changes can have on speed etc.
16-08-2012 2:40 PM
16-08-2012 2:43 PM
16-08-2012 2:51 PM
16-08-2012 3:06 PM
16-08-2012 5:31 PM
Quote from: x47c
That is certainly my recent experience. The rate went up a few days into the ADSL2+ training period, as x47c says it will.
