Blue light on router but no connection
lizzief25
I have been having problems since yesterday. Did a factory reset yesterday which sorted the issue but the same has happened again this morning. I have done another factory reset, shows as connected on my mobile settings and on my laptop but when I try to go online it says cannot connect to the server. On smart TV the settings are showing as not connected to the internet. Can’t get through on the phone to Plusnet. Any advice appreciated, thanks.
26 REPLIES 26
Fixes: 1,483
Re: Blue light on router but no connection
Log in to the Hub One by using http://192.168.1.254 in the address bar.
Username and password are located on the router - it will be admin
Once logged in go to:
Advanced Settings > Broadband
what is Broadband Username?
lizzief25
setup@plusdsl.net
Legend
Fixes: 255
Disconnect the DSL cable, change 'setup' to your 'username', press 'save' and then reconnect DSL.
lizzief25
What’s the DSL cable?
Legend
Fixes: 255
The one between your router and the phone socket.
lizzief25
Got it. I am getting a screen saying ‘Sessions number - no more than 100 sessions at a time are allowed’
Legend
Fixes: 255
@lizzief25 I've seen that in the dim and distant past, but can't remember the fix - sorry.
@dvorak Any idea?
Fixes: 1,483
restart the router with the cable unplugged and then try and connect to it again.
Legend
Fixes: 255
Cheers @dvorak - was just going to make that suggestion after checking .😁
lizzief25
I did manage to get in and change my username and got the blue light back but now it’s gone again and I have an orange horizontal light and a steady red b on the hub.
Legend
Fixes: 255
Did you check the password as well?
Now you have it reconnected - after checking the password, reboot the router while it is connected.
lizzief25
By reboot do you mean restart or pin in the back job?
Legend
Fixes: 255
I'd try a restart first, if that failed, the pin, and if that failed, come back and we can look further.
lizzief25
Restart failed but will try the pin in back. Might that reset my username though back to setup@plusdsl.net?
