Blocked port oddness
- Blocked port oddness
05-04-2009 3:30 PM
Dearest Group,
For sometime I had port 23230 open (for Azureus). Since yesterday I have discovered something external to me is blocking access to that port.
I ran some tests and discovered I can successfully open standard ports (20,21,80,443,5900 etc), but anything out of the norm is a no-go.
Raised a ticket on this one, also the PN firewall has been verified as off.
Anyone else noticed this? Is it a Conficker blocking thing?
Cheers,
Richard
Cheers,
Richard
Message 1 of 7
(1,588 Views)
6 REPLIES 6
Re: Blocked port oddness
05-04-2009 5:54 PM
Quote from: rockyhorror I ran some tests and discovered I can successfully open standard ports (20,21,80,443,5900 etc), but anything out of the norm is a no-go.
I've had no problem accessing cvsup3.uk.FreeBSD.org on port 5999 today (I don't think that's a standard port).
Quote Is it a Conficker blocking thing?
Dunno. Sounds more like a neat way of getting round the word censor.
Message 2 of 7
(606 Views)
05-04-2009 7:49 PM
Quote Dunno. Sounds more like a neat way of getting round the word censor.
Good call!
I don't think it would give you trouble with outbound traffic (if I understand you correctly). It's just a case of if you open a non-standard port on your router, incoming traffic is still blocked.
Cheers,
Richard
Message 3 of 7
(606 Views)
05-04-2009 7:54 PM
Try this to see if you think it is Conflicker http://www.confickerworkinggroup.org/infection_test/cfeyechart.html
Other thing is have you installed updated any security software on your PC?
Have you gone over your allowance for your package?
Message 4 of 7
(606 Views)
06-04-2009 10:55 AM
In answer to your Q's: No,No and No.
Just to re-iterate common ports can be opened successfully. The only issues are external to me.
Message 5 of 7
(606 Views)
06-04-2009 10:59 AM
Check also the safe surf and other blocking issues on the PN user site, It might be worth ENABLING then disabling the PN firewall to see if it is that throwing a huff.
Message 6 of 7
(606 Views)
06-04-2009 1:05 PM
Tried that already...
A conspiracy theorist might think that http://news.bbc.co.uk/1/hi/technology/7985339.stm has something to do with it! I hope not.
Cheers,
Richard
Cheers,
Richard
Message 7 of 7
(606 Views)
