Binatone ADSL500 & Vista
- Binatone ADSL500 & Vista
- « Previous
- Next »
Re: Binatone ADSL500 & Vista
14-09-2007 3:32 PM
Well the new Voyager 2091 arrived at lunchtime today, have spent the last 3 hours trying to get it to work, back on my old USB modem just to get on this forum
Could I have a faulty router?
Everything goes fine but it will not accept my username and password.
When I run a diagnostic test it passes everything except Ethernet which shows 'Down' as it isn't connected but Test authentication with ISP shows Fail.
This a USB connection only, I followed the instructions to the letter, have rebooted my PC and the router several times but still no joy.
Message 31 of 36
(350 Views)
14-09-2007 3:36 PM
Hmm.
Test authentication suggests a username/password failure. I'll run some tests and see what I can find out.
Message 32 of 36
(350 Views)
14-09-2007 4:15 PM
Wrong Password
Thanks for that James back online now.
Well I won't need any radiators on in my den this winter, this router sure runs hot
Message 33 of 36
(350 Views)
02-11-2007 3:11 PM
Quote from: Richchad
Quote from: James I know
If you move to BBYW (should it be suitable for you) you can get one, barring the P&P charges.
If I switch to BBYW Option 2 and find it doesn't suit me can I switch back? (and keep the modem if I stay for 12 months)
Quote from: Jameseh Yes, that would be absolutely fine.
James do you remember this conversation a couple of months ago, well can I switch back to BB+ without incurring any charges?
I have had a router but believe this is not a problem as long as I do not leave.
It is that I have just been informed that I have exceeded my 8GB limit, in all the time I have been with PN I have never used more than 5GB
I assume the peak time change has caused me to exceed 8GB as I use my PC mostly during the day.
Message 34 of 36
(350 Views)
02-11-2007 3:58 PM
Hi Richchad,
I've moved you back onto broadband plus, all you need to do is disconnect and then reconnect in order to pick up the change.
Hope that helps,
Hope that helps,
Message 35 of 36
(350 Views)
02-11-2007 4:00 PM
Many thanks Orbrey.
Message 36 of 36
(350 Views)
- « Previous
- Next »
