Binatone ADSL500 & Vista
- Binatone ADSL500 & Vista
11-09-2007 5:56 PM
Yes I still have a Binatone ADSL500...
I know I need to get a router...lol
Re: Binatone ADSL500 & Vista
11-09-2007 5:58 PM
Afaik, it's just the Speedtouch that does.
11-09-2007 6:08 PM
Time to get a router - If cash is a problem try here
11-09-2007 6:56 PM
What sort of problems?
Quote from: Peter The drivers had problems running with XP SP2.
As I said elsewhwre some indication of what amongst that lot is to be recommended could be useful to poor benighted Binatoners
11-09-2007 8:09 PM
Quote from: PJ Or switch to BBYW and get a router for free (provided you stayed with PlusNet for twelve months).
There is a £5.99 delivery charge on equipment.
What make of router is free for option 2 and if I switch from Broadband Plus to Option 2 what is the difference between the two products, also is there a charge to switch?
11-09-2007 8:16 PM
Quote What make of router is free for option 2
This is either the BT Voyager 210 (wired 1 port ethernet/usb) router, or the BT Voyager 2091 (wireless 1 port ethernet/usb) router.
Quote if I switch from Broadband Plus to Option 2 what is the difference between the two products
There is extra webspace on the BBYW option 2 and double the peak time allowance (8gb as opposed to 4) though the peak time runs from 8am to midnight as opposed to 4pm to midnight on the broadband plus.
Quote is there a charge to switch?
Nope.
Hope this helps,
12-09-2007 8:53 AM
On a slightly different note, I am geting a new Vista PC hence the question about my Binatone USB ADSL500, I want to keep my existing PC but link it to my new one, it doesn't need to be connected to the net as I will just use it for maybe backing up and running stuff that may not work on Vista like my scanner, my question is can I link it with the BT Voyager 210 to enable transfer of files etc?
Not quite sure how I am going to operate the two PC's with one keyboard, monitor etc but believe a Belkin switch2 will do it or by making my old PC a terminal server.
12-09-2007 9:00 AM
You need a 2 port KVM switch to use a single keyboard / mouse / screen with 2 PCs. But be careful if you have a USB keyboard or mouse as most KVMs only support PS2 mouse/keyboard. They do not make your old PC a terminal server, they just switch the devices between the two PCs.
12-09-2007 9:14 AM
I have looked at the Belkin Switch2's and I think this one would do it as I have a monitor with DVI connection and USB keyboard and mouse.
http://catalog.belkin.com/IWCatProductPage.process?Product_Id=357928#
If I wanted to make my old PC a terminal server would it be possible with the connections through the Voyager 210 or would I need to add an Ethernet card to my old PC?
Sorry about all the questions.
12-09-2007 9:22 AM
Quote from: Richchad Thanks for that Peter, just to clarify, my existing PC only has a USB modem connection, no Ethernet, the new PC will have a Ethernet connection and this is the one I want to connect to the internet, will this work with the Voyager 210?
Yes, as I said one PC can connect via USB and the other via Ethernet.
Quote I have looked at the Belkin Switch2's and I think this one would do it as I have a monitor with DVI connection and USB keyboard and mouse.
That appears to support DVI and USB but not PS2 so as long as both your mouse and keyboard are USB it will be fine.
Quote If I wanted to make my old PC a terminal server would it be possible with the connections through the Voyager 210 or would I need to add an Ethernet card to my old PC?
The old PC will connect using USB, the new using Ethernet.
I think you may be confusing terminal server (where you can have several users logged into the PC to run applications) and a file server where it allows access to files on the PC. With both PCs connected to the router you should be able to access files from either PC although networking between XP and Vista is very difficult to set-up.
I would strongly urge you don't use Vista as it is so far one of the worst MS operating systems to date and has lots of compatibility and other problems.
12-09-2007 9:32 AM
Quote from: Peter
Peter, many thanks for all the help, but why did you put the cat among the pidgeons with that last bit, I have been round and round with this question on a number of forums but mostly if to go with Vista 32 bit or 64, and most feedback is that there is no support for 64 but 32 seems to be stable and gaining more and more support now, to stay with XP seems a backward step....decisions decisions
12-09-2007 9:32 AM
12-09-2007 11:09 AM
I don't think I want to switch to BBYW as I use my pc mostly during the day, is there any way I can get a free modem by agreeing to stay without switching products for at least 12 months especially as the modem PN supplied is no longer supported for Vista?
12-09-2007 11:14 AM
12-09-2007 11:16 AM
Quote from: James Any ethernet modems or routers should work absolutely fine on Vista.
James, you missed my point, I am after a free modem..lol
