Billion 7800N
- Billion 7800N
Re: Billion 7800N
24-11-2011 1:05 PM
Re: Billion 7800N
24-11-2011 1:13 PM
Have you got any noise on the line that's audible?
Re: Billion 7800N
24-11-2011 1:18 PM
Quote from: nozzer Should be better than that with your line attenuation..
According to Kitz I should sync at 6944kbps. The attentuation on the Billion is wrong, it's definately 40dB.
Quote from: nozzer Have you got any noise on the line that's audible?
I have run the quiet line test several times and my line is perfectly clear. I raised a fault but nothing was found. I don't think this is going anywhere unless an Admin wants to look into this a bit more...
Re: Billion 7800N
24-11-2011 1:27 PM
Re: Billion 7800N
24-11-2011 1:30 PM
Quote from: sjrinfroyle ...my attentuation is shown as 49dB but it is actually 40dB as shown by many other routers and by Plusnet.
Plusnet? Did they tell you it was 40dB?
Re: Billion 7800N
24-11-2011 1:31 PM
edit: oops!
Re: Billion 7800N
24-11-2011 1:32 PM
Quote from: nozzer How do you know it's definitely 40dB?
Plusnet have confirmed this to me and I have used about 8 different routers and they have all reported 40dB. Plus, a neighbour gets 43dB on another router and they are just a few doors away.
I'll plug the Billion back in tonight and I'll post a RouterStats graph showing the drops.
Does anybody have any suggestions as this point in time? I have tried plugging into the master socket, different faceplate, different cables, different router. Adam has told me on here that my line is performing well but it never used to drop at 6dB and this is why I'm frustrated.
Re: Billion 7800N
24-11-2011 1:33 PM
Re: Billion 7800N
24-11-2011 1:36 PM
Re: Billion 7800N
24-11-2011 1:39 PM
Adam commented on your connection here http://community.plus.net/forum/index.php/topic,100203.msg849294.html#msg849294
Re: Billion 7800N
24-11-2011 1:46 PM
What are you using? If it's the full version, try using the Lite version; might be just something to do with the RStats software data handling.
Re: Billion 7800N
24-11-2011 3:10 PM
Re: Billion 7800N
24-11-2011 3:11 PM
Quote from: nozzer Now then, here's a thing! I get those apparent sudden drops in SNRM, BUT only when plotting it on Routerstats. If I plot it on Routerstats Lite they never appear!
I can't browse the web and the DSL light goes off when this happens so I am losing connection.
Re: Billion 7800N and My Connection (Is it Faulty?) - Routerstats Graphs!
24-11-2011 3:33 PM
If it's genuine, your line is picking up noise from somewhere that's swamping the signal.
24-11-2011 3:34 PM
