Better access to BT speed tester !
Fixes: 30
Just running my Monday Morning BT speed test......
it now says "there is a 1 hour minimum wait between successful speed test !
Yippee !....... Cheesy
5 REPLIES 5
Re: Better access to BT speed tester !
You are right.  Thanks for the heads up.  That is good news.
tobykim
Only thing we need now is for it to work properly and give the correct results
W1ngD1ngs
I only noticed the speed tester falling over after the change!  Co-incidence...or....?  :crazy:
Chris
Legend
Fixes: 168
Bob's just posted about this in the announcement section too: http://community.plus.net/forum/index.php/topic,83484.0.html
Fixes: 62
Quote from: Strat
Thanks Bob Smiley
Shutter noticed the change also http://community.plus.net/forum/index.php/topic,83361.msg686366.html#msg686366
