Best BT Openreach ADSL faceplate?
- Best BT Openreach ADSL faceplate?
- « Previous
- Next »
Re: Best BT Openreach ADSL faceplate?
03-05-2013 7:43 PM
Link Information
Uptime: 0 days, 6:56:14
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 443 / 6,763
Data Transferred (Sent/Received) [MB/GB]: 134.46 / 3.60
Output Power (Up/Down) [dBm]: 12.9 / 0.0
Line Attenuation (Up/Down) [dB]: 27.2 / 49.0
SN Margin (Up/Down) [dB]: 22.9 / 6.3
Loss of Link (Remote): -
Error Seconds (Local/Remote): 768 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 17 / 3,104
HEC Errors (Up/Down): 12 / 3,828
03-05-2013 10:33 PM
In the meantime, how is your ping currently? Also run the BT speedtester but don't bother with the Diagnostic this time, just run the first test. If you get a slow upload, run the tester again immediately and see if it's any different, if not run it again immediately.
You can actually run this first test as frequently as you like. The next (Diagnostic) part is the part you have to wait 10 minutes between tests and no more than 3 per hour, but the primary benefit of that is to get the profiles which we aren't overly interested in at this time as that side of it seems OK in relation to sync.
04-05-2013 12:14 AM
Quote from: Damian78 Phone exchange:
FLEETWOOD
Estimated line speed:
6Mb (This may vary between 5Mb and 7Mb) - Checked on 2013-04-23 18:17:38
Current line speed:
6 Mb
I had checked this with website samknows and you could getting FTTC as it say it available in your area?
04-05-2013 12:19 AM
04-05-2013 10:23 AM
As for FTTC some parts of the town have it but our actual cabinet (38) isn't upgraded yet with no lead time 😞
Will try that test again shortly.
04-05-2013 11:24 AM
Last test my ping was 142. Download dropped to 3.80.
Just run 60 secs after that and ping is 37. Downloads 5.82.
Arrrrrrggggghhhhh
04-05-2013 12:58 PM
Doh! But since reseting it the speed has remained constant as has the ping.
The SNR seems to vary between 6.0 to 6.3. Not sure why.
Looks like I'm not "commercially viable" for an FTTC upgrade according to BT Openreach. I cannot believe this considering all the properties being built but have lobbied it with my councillor now. Joy!
04-05-2013 2:41 PM
Whilst you are still on this old filter can you post the full stats please.
Also if you could run the BT speedtester first stage wired, 3 times in quick succession noting the results each time and post them please.
04-05-2013 2:44 PM
Will try to post stats later and connect up wired again.
04-05-2013 6:22 PM
04-05-2013 6:51 PM
This is the old BT ADSL filtered plate.
11-05-2013 1:50 PM
Link Information
Uptime: 0 days, 0:05:49
Bandwidth (Up/Down) [kbps/kbps]: 443 / 6.835
Data Transferred (Sent/Received) [kB/kB]: 383,31 / 205,01
Output Power (Up/Down) [dBm]: 12,8 / 0,0
Line Attenuation (Up/Down) [dB]: 27,1 / 49,0
SN Margin (Up/Down) [dB]: 21,5 / 6,0
Error Seconds (Local/Remote): 10 / 0
CRC Errors (Up/Down): 0 / 16
HEC Errors (Up/Down): 0 / 16
11-05-2013 2:28 PM
If DLM is happy with the line it'll lower the Target SNRM don't forget. We'll have a better idea looking at some stats tonight, well after dark.
11-05-2013 11:26 PM
Link Information
Uptime: 0 days, 9:43:08
Data Transferred (Sent/Received) [MB/GB]: 51,68 / 1,13
SN Margin (Up/Down) [dB]: 21,7 / 4,6
Error Seconds (Local/Remote): 2.004 / 0
CRC Errors (Up/Down): 0 / 2.946
HEC Errors (Up/Down): 0 / 6.426
12-05-2013 9:52 AM
Edit: spelling
- « Previous
- Next »
