Best BT Openreach ADSL faceplate?
- Best BT Openreach ADSL faceplate?
Re: Best BT Openreach ADSL faceplate?
24-04-2013 9:23 PM
There's nothing wrong with your syncs speed, it should give you a profile of 6.87Mbps so you should be getting download speeds near that 6.7 you mentioned.
Can you run the BTw Performance test (ignore the red preamble except make sure no other programs are using the Internet) and at the end of the first run, click the Further Diagnostics button, enter just your Phone number and Run the Further Diagnostics Test. Do a Copy and Paste of the results and post here (no need to grab an image).
Can you also check your Current Line speed (Login required) (don't post your phone number!).
24-04-2013 9:32 PM
Will run the BT Speedtest shortly as currently streaming from Lovefilm.
My current line speed is:
Phone exchange:
FLEETWOOD
Estimated line speed:
6Mb (This may vary between 5Mb and 7Mb) - Checked on 2013-04-23 18:17:38
Current line speed:
6 Mb
24-04-2013 10:32 PM
Was that a reboot of the modem/router 29hrs ago and have you rebooted twice altogether since the last power up or have you had loss of sync?
Can you hear/have you heard any crackling or other noises on the line when using the phone? Have you had any problems with incoming or outgoing calls?
25-04-2013 7:30 AM
1. Best Effort Test: -provides background information.
Download Speed
6.24 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 6.24 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 6.88 Mbps
Upload Speed
0.37 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.37Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
That's the BT Wholesale test.
Interleaving is off. Not had any problems with my phone line crackling or not receiving calls (since the first ADSL faceplate died). New one should be hear today so can post results later after changing it.
Any suggestions?
25-04-2013 11:38 AM
25-04-2013 11:43 AM
Just need a friendly PlusNet bod to look at this 🙂 Anyone?
25-04-2013 11:54 AM
25-04-2013 11:55 AM
@Damian
also, the following method is probably the best to use when you need to lose sync for any reason - altering settings, changing filters, etc -
Log in to the Modem/Router, in the Internet box, click Disconnect to drop the PPP Internet session (this is not the sync), wait about a minute then power down the modem/router. Wait another minute and then unplug from the line, change whatever, if router settings then try and do them all off-line so you can reboot etc. Take at least 10 minutes doing all this before plugging in again and powering up. Log in to the modem/router and click Connect to establish a new PPP session.
This way the exchange DLM doesn't see your loss of sync as a dropping connection. HTH.
25-04-2013 11:57 AM
I'll try that method tonight.
25-04-2013 7:00 PM
Router stats:
Uptime: 0 days, 1:29:27
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 443 / 6,816
Data Transferred (Sent/Received) [MB/GB]: 114.88 / 2.93
Output Power (Up/Down) [dBm]: 12.9 / 0.0
Line Attenuation (Up/Down) [dB]: 27.1 / 49.0
SN Margin (Up/Down) [dB]: 22.6 / 6.1
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 3 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 59,271 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 111
HEC Errors (Up/Down): 0 / 264
After the change out the PING was 28ms with a download of 6.04mbps
Router stats:
Uptime: 0 days, 0:01:11
Bandwidth (Up/Down) [kbps/kbps]: 443 / 6,903
Data Transferred (Sent/Received) [kB/kB]: 29.43 / 72.82
Line Attenuation (Up/Down) [dB]: 27.0 / 49.0
SN Margin (Up/Down) [dB]: 21.1 / 6.0
Error Seconds (Local/Remote): 1 / 0
HEC Errors (Up/Down): 0 / 5
So we seem to be moving in the right direction.
Anything else I can do to boost more speed!!!??
25-04-2013 8:13 PM
A change in ping, but quite why it was so poor previously as Interleaving was off, I'm not sure but part of it may have been dependant on which Gateway you are on, another part may be related to any congestion at the exchange.
Secondly, the reset starts with a Target SNRM of 6dB whereas previously your had been at 3dB.This means you get slightly slower speed until the Exchange DLM decides to lower the Target to 3dB, so it's a matter of patience.
Whether the Pro add-on is beneficial depends. Which Package are you on, and what are your main uses of the connection? - Streaming is obviously one thing based on your earlier post. Do you do gaming and need as low a ping as possible?
Keep a note of which Gateway you are on Sometimes changing Gateway is beneficial. If you want to Gateway hop, log in to your modem/router and go to the Internet Box as shown here and click Disconnect. This drops the PPP session to the ISP. Wait about 30 seconds and then Click Connect - that's similar to the method mentioned before except you are npt powering down and dropping sync, just starting a new session which usually starts on a new Gateway.
25-04-2013 8:19 PM
25-04-2013 8:23 PM
25-04-2013 11:47 PM
26-04-2013 12:27 AM
