Belkin F5D 7634-4 and Routerstats
- Belkin F5D 7634-4 and Routerstats
19-03-2012 1:53 PM
Re: Belkin F5D 7634-4 and Routerstats
19-03-2012 2:12 PM
Log on to your router by following this link http://192.168.2.1
Then click connection type on the left hand side.
Then click PPPoA
Username will be: [username]@plusdsl.net
Password: your password
IP assigned by ISP : Yes
VPI/VCI : 0/36
encapsulation: VC/MUX
MTU: 1454
Hope this helps
19-03-2012 3:20 PM
Then select the Router Seach Text tab and click Get Page. Highlight values and click the buttons as advised in the Help pages to teach the program where to find the stats.
When it comes to configuring graphs you might find the hints in the How to Use Routerstats topic helpful.
David
20-03-2012 2:06 PM
20-03-2012 5:51 PM
If not then selecting the "This router does not require a Username" checkbox should enable Routerstats to get the stats page information.
If you have to supply a username (but empty password) the "Login" checkbox needs to be ticked with the username entered in its textbox. The password textbox should be empty if Routerstats will accept that (sorry - I don't know whether it does or not).
If you can't have a username without a password than creating a new user which has one should solve the problem. In fact I'd be inclined to do this anyway in case the router gets upset if the same user logs on more than once (eg Routerstats and your browser).
21-03-2012 4:46 PM
21-03-2012 7:10 PM
If that is the case you could try selecting the Use Source B checkbox and click Get Page again. This will show the HTML text for the page; finding the values required is less easy with this source but once located try the highlight then button click process again.
22-03-2012 7:22 PM
The items on this page are unsupported.
Monitoring Index:
More Info
ADSL Status Information:
Status
Data Rate Information
Defect/Failure Indication
Statistics
Status:
Configured
Current
Line Status
SHOWTIME
Link Type
Interleaved Path
[Go Top]
Data Rate:
Stream Type
Actual Data Rate
Up Stream
448 (Kbps.)
Down Stream
1824 (Kbps.)
[Go Top]
Operation Data / Defect Indication:
Operation Data
Operation Data
Upstream
Downstream
Noise Margin
4 dB
10 dB
Attenuation
63 dB
--- dB
Defect Indication
Indicator Name
Near End Indicator
Far End Indicator
Fast Path FEC Correction
0
0
Interleaved Path FEC Correction
55452
4010
Fast Path CRC Error
0
0
Interleaved Path CRC Error
10025
780
Loss of Signal Defect
0
4
Fast Path HEC Error
0
0
Interleaved Path HEC Error
8571
493
[Go Top]
Statistics:
Received Cells
9631262
Transmitted Cells
1142777
This is what I get with get page , same as from the router
22-03-2012 11:31 PM
Quote from: stathe Actual Data Rate
Up Stream
448 (Kbps.) <<<< Upstream sync speed (Tx Sync)
Down Stream
1824 (Kbps.) <<<< Downstream sync speed (Rx Sync)
Noise Margin
4 dB <<<< Downstream noise margin (Rx Noise)
10 dB <<<< Upstream noise margin (Tx Noise)
When that information is displayed with Get Page does Routerstats allow you to highlight each of the numbers I've marked in red so you can select them using the indicated buttons?
23-03-2012 12:17 PM
Router Setup
Home | Help |
ADSL > ADSL Status
Monitoring Index:
More Info
Status
Statistics
Status:
Configured
Current
Line Status
SHOWTIME
Link Type
Interleaved Path
[Go Top]
Data Rate:
Stream Type
Actual Data Rate
Up Stream
448 (Kbps.)
Down Stream
1824 (Kbps.)
[Go Top]
Operation Data
Operation Data
Upstream
Downstream
Noise Margin
4 dB
10 dB
Attenuation
63 dB
--- dB
Defect Indication
Indicator Name
Near End
Indicator
Far End
Indicator
Fast Path FEC
Correction
0
0
Interleaved Path
FEC Correction
21969
4382
Fast Path CRC
Error
0
0
Interleaved Path
CRC Error
10887
795
Loss of Signal
Defect
0
5
Fast Path HEC
Error
0
0
Interleaved Path
HEC Error
9305
501
[Go Top]
Statistics:
Received Cells
9871101
Transmitted Cells
1196713
[Go Top]
23-03-2012 12:31 PM
<head>
<title></title>
<!--<meta http-equiv="Content-Type" content="text/html;
charset=windows-1252">--><META http-equiv=Content-Type content="text/html;
charset=iso-8859-1" >
<link rel="stylesheet" href="main_router.css" type="text/css">
<script language="JavaScript">
setTimeout('parent.location.href="/login.stm";
',600000);
ipmUcast="The first entry of IP address must be within range 1 - 223.";
function IpToLong(addr) {
var IP;
var val1, val2, val3, val4, longIP;
IP = addr.split(/\./);
val1 = new Number(IP[0]);
val2 = new Number(IP[1]);
val3 = new Number(IP[2]);
val4 = new Number(IP[3]);
longIP = val1 * 0x1000000 + val2 * 0x10000 + val3 * 0x100 + val4;
return longIP;
function isBlank(s)
for(i=0;
i<s.length;
i++)
c=s.charAt(i);
if((c!=' ')&&(c!='\n')&&(c!='\t'))return false;
return true;
function isIncludeDQuote(s)
for(i=0;
i<s.length;
i++)
c=s.charAt(i);
if((c=='"'))return true;
return false;
function isIncludeBSlash(s)
for(i=0;
i<s.length;
i++)
c=s.charAt(i);
if((c=='\\'))return true;
return false;
function isBlank_Zero(s)
for(i=0;
i<s.length;
i++){
c=s.charAt(i);
if((c!=' ')&&(c!='\n')&&(c!='\t')&&(c!='0'))return false;
return true;
// function isNValidInt(s)
// if (s.indexOf(".") != -1)
// return true;
// else
// return false;
function isNvaliduser(s) {
var j,x = 0;
for(var i = 0;
i < s.length;
i++) {
var c = s.charAt(i);
if ((c=='<') || (c=='>') || (c=='&'))
//alert(c);
return true;
return false;
var i, c;
for (i=0;
i<s.length;
i++) {
c = s.charCodeAt(i);
if ((c < 48) || (c > 57))
return true;
return false;
function isNegInt(s)
if (s<0)
return true;
else
return false;
function isNValidIP(s) {
if((isBlank(s))||(isNaN(s))||(isNValidInt(s))||(isNegInt(s))||(s<0||s>255))
return true;
else
return false;
function isNValidLastIP(s) {
if((isBlank(s))||(isNaN(s))||(isNValidInt(s))||(isNegInt(s))||(s<1||s>254))
return true;
else
return false;
function isNValidMask(s) {
if ((s == 255) || (s == 254) || (s == 252) || (s == 248) || (s == 240) || (s == 224) || (s == 192) || (s == 128) || (s == 0))
return false;
return true;
function isNValidLastMask(s) {
if ( (s == 252) || (s == 248) || (s == 240) || (s == 224) || (s == 192) || (s == 128) || (s == 0) )
return false;
return true;
function isNValidSubnetMask(s1, s2, s3, s4) {
if (s1 != 255)
return true;
if ((isNValidMask(s2)) || (isNValidMask(s3)) || (isNValidLastMask(s4)))
return true;
if (s2 != 255)
if ((s3 != 0) || (s4 != 0))
return true;
if ((s3 != 255) && (s3 != 0))
if ((s2 != 255) || (s4 != 0))
return true;
return false;
function isNValidPort(s) {
if((isBlank(s))||(isNaN(s))||(isNValidInt(s))||(isNegInt(s))||(s<1||s>65535))
return true;
else
return false;
function isNValidPortAllowZero(s) {
if((isBlank(s))||(isNaN(s))||(isNValidInt(s))||(isNegInt(s))||(s<0||s>65535))
return true;
else
return false;
function is2Hex(s) {
var j,x = 0;
for(var i = 0;
i < s.length;
i++) {
j = parseInt(c,16);
if ((j == 0) || (j == 1)|| (j == 2)|| (j == 3)|| (j == 4)|| (j == 5)|| (j == 6)
|| (j == 7)|| (j == 8)|| (j == 9)|| (j == 10)|| (j == 11)|| (j == 12)|| (j == 13)|| (j == 14)|| (j == 15)) {
if(x==1) return false;
x=1;
return true;
function isHex(s) {
var j, x = 0;
for (var i = 0 ;
i < s.length;
i++)
j = parseInt(c, 16);
if (!((j == 0) || (j == 1)|| (j == 2)|| (j == 3)|| (j == 4)|| (j == 5)|| (j == 6)
|| (j == 14)|| (j == 15))) {
x = 1;
if (x == 1) return false;
return true;
function isNValid(s) {
if( isBlank(s) || is2Hex(s))
return true;
else
return false;
function isNValids(s) {
if( isBlank(s) || isHex(s))
return true;
else
return false;
function MM_openBrWindow(theURL,winName,features){
window.open(theURL,winName,features);
function getElementsByFieldName(target_form, field)
var i;
var form;
var value;
if(target_form == null || field == null) return -1;
for(i=0;
i<target_form.length;
i++)
if(target_form.elements.name == field)
return i;
return -1;
// function isHex(s)
// var c, j;
// for(var i = 0;
i < s.length;
i++) {
// c = s.charAt(i);
// j = parseInt(c,16);
// if ((j == 0) || (j == 1)|| (j == 2)|| (j == 3)|| (j == 4)|| (j == 5)|| (j == 6)
// || (j == 7)|| (j == 8)|| (j == 9)|| (j == 10)|| (j == 11)|| (j == 12)|| (j == 13)|| (j == 14)|| (j == 15)) {
// else{
// return false;
// return true;
function isNValidNum(s) {
if((isBlank(s)) || (isNaN(s))||(isNValidInt(s))||(isNegInt(s)))
return true;
else
return false;
function isNValidUnicastIP(s) {
if((isBlank(s))||(isNaN(s))||(isNValidInt(s))||(isNegInt(s))||(s<=0||s>=224))
return true;
else
return false;
function MM_jumpMenu(targ,selObj,restore){ //v3.0
eval(targ+".location='"+selObj.options[selObj.selectedIndex].value+"'");
if (restore) selObj.selectedIndex=0;
function refresh(){
window.location.reload();
return true;
function clear1() {
window.status="";
</script>
</head>
<body topmargin="0" leftmargin="0" marginheight="0" marginwidth="0" onload="clear1()">
<a NAME="top">
<table border="0" cellspacing="0" cellpadding="0" align="left" width="100%" height="100%">
<tr>
<td colspan="3" bordercolor="#FFFFFF" height="64">
<table bgcolor="#cccccc" width="100%" border="0" cellspacing="0" cellpadding="0">
<script language="JavaScript" src="/prototype.js"></script>
var ht_isLogined=1;
function showConnectTest(reqObj) {
var ok_text;
var fail_text;
ok_text ='<font face="arial" color="#0000ff">'+'Connected'+'</font>';
fail_text ='<font face="arial" color="#FF0000">'+'No Connection'+'</font>';
if(reqObj.responseText.indexOf("OK") >=0)
//my_text=reqObj.responseText.substring(reqObj.responseText.indexOf("OK")+2,reqObj.responseText.indexOf("XX"));
document.getElementById("connect_state").innerHTML = ok_text;
else if(reqObj.responseText.indexOf("NO") >=0)
//my_text=reqObj.responseText.substring(reqObj.responseText.indexOf("NO")+2,reqObj.responseText.indexOf("XX"));
document.getElementById("connect_state").innerHTML = fail_text
//if(reqObj.responseText.indexOf("WPS") >=0)
// window.open('wps_showInit.stm','WPS','toolbar=0,status=0,menubar=0,scrollbars=0,resizable=0,width=300,height=200,left=150,top=150,resizable=0,depended=1, location=0');
// Element.update("connect_state",reqObj.responseText);
function doConnectTest() {
var url = "/cgi-bin/doConnectTest.exe";
var ajax = new Ajax.Request( url,
method: 'post',
parameters:'',
onComplete:showConnectTest
if(ht_isLogined == 1)
var speed=10000;
setInterval("doConnectTest()",speed);
</script>
<tr>
<td rowspan="3" width="20" valign="middle"><a href="http://www.belkin.com"><img src="/images/head_logo.gif" border="0" width="140" height="50"></a></td>
<td rowspan="3" width="220" valign="middle" class="head_bold1">
Router Setup</td>
<td colspan="4" height="21" align="right" nowrap>
</td>
</tr>
<tr>
<td colspan="4" height="15"></td>
</tr>
<tr>
<td width="150" height="28"><img src="/images/shim.gif" width="1" height="28"></td>
<td height="28"></td>
<td height="28" align="right" nowrap class="top_nav">
<nobr>
<a href="/index.stm" class="top_nav">Home</a> |
<a href="/help.stm" class="top_nav">Help</a> |
<script language="javascript">
var ht_isLogined=1;
document.write('<a href="/cgi-bin/logout.exe" class="top_nav">Logout</a>
else
document.write('<a href="/cgi-bin/top_login.exe" class="top_nav">Login</a>
var adsl_data_rate="1824/448(Kbps)";
var adsl_status="Connected";
var autofw_enable=1;
var if_number=3;
var bWanConnected=1;
var wan_type=7;
var wan_ip="81.174.133.160";
var wan_subnet_mask="255.0.0.0";
var wan_gateway="195.166.128.242";
var primary_dns="212.159.6.9";
var secondary_dns="212.159.6.10";
var lan_gateway_ip="192.168.2.1";
var lan_gateway_mask="255.255.255.0";
var dhcp_enable=1;
var dhcp_start_ip="192.168.2.2";
var dhcp_end_ip="192.168.2.100";
var firewall_func=1;
var firewall_enable=1;
var upnp_func=1;
var upnp_enable=1;
var wireless_func=1;
var wireless_enable=1;
var wireless_channel="Auto";
var wireless_bssid="Enabled";
var wireless_mode="Mixed (11b+11g)";
var printer_func=0;
var dhcp_client_num=3;
var lan_mac_addr="00-22-75-7D-3B-79";
var wlan_mac_addr="00-22-75-7D-3B-79";
var wan_mac_addr="00-22-75-7D-3B-7A";
document.write("<span class=top_nav><font color=#000000>Internet Status:</font>");
if(bWanConnected==1)
document.write('<b><font face="arial" size="2" color="#0000ff"><div id="connect_state" style="display:inline">Connected</div></font></b></span>');
else
document.write('<b><font face="arial" size="2" color="#FF0000"><div id="connect_state" style="display:inline">No Connection</div></font></b></span>');
</script>
</nobr>
</td>
<td height="28" align="right"></td>
</tr>
</table>
</td>
</tr>
<tr>
<td valign="top" width="130" height="100%">
<script type="text/javascript" language="JavaScript">
var html_array = document.location.href.split ("/");
var htmlstr = html_array[3];
function javamagic(srcElement, pageName, pageOpen)
var targetId;
if (pageOpen == 1){
document.location.href = pageName;
</script>
<table width="141" border="0" cellspacing="0" cellpadding="0" background="../image/v_p6.gif" height="100%">
<tbody>
<tr bgcolor='666666'>
<td vAlign=top width=130 height="100%">
<table cellSpacing=0 cellPadding=0 width=140 align=left bgcolor='666666'>
<tbody>
<!-- LAN -->
<tr id="Out3d">
<td width="5">
</td>
<script>
var subhtmlstr= htmlstr.substring(0,3);
if((htmlstr=="lan_main_0.stm")||(subhtmlstr=="lan")){
document.write('<td colspan="2" height="20" width="140" class="Menu_section">');
document.write('<a href=javascript:javamagic("Out3","/lan_main_0.stm",1);
><font color=#ffff00>LAN Setup</font></a></td>');
}else{
><font color=#ffffff>LAN Setup</font></a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="lan_dhcp.stm"){
document.write('<td class="Menu_leftLink">');
document.write('<font color=#6699ff>DHCP Client List</font></td>');
else{
document.write('<a href=/lan_dhcp.stm target=_self class="menuharf">DHCP Client List</a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="lan_main.stm"){
document.write('<font color=#6699ff>LAN Settings</font></td>');
else{
document.write('<a href=/lan_main.stm target=_self class="menuharf">LAN Settings</a></td>');
</script>
</tr>
<!-- WAN -->
<tr id="Out3d">
<td width="5">
</td>
<script>
if((htmlstr=="wan_main_0.stm")||(htmlstr=="setup_dns.stm")||(htmlstr=="ddns.stm")||(subhtmlstr=="wan")||(htmlstr=="setup_q21.stm")||(htmlstr=="setup_q22.stm")||(htmlstr=="setup_q23.stm")||(htmlstr=="setup_q24.stm")||(htmlstr=="setup_q25.stm")){
document.write('<a href=javascript:javamagic("Out3","/wan_main_0.stm",1);
><font color=#ffff00>Internet WAN</font></a></td>');
}else{
><font color=#ffffff>Internet WAN</font></a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="wan_main.stm"||htmlstr=="setup_q21.stm"||htmlstr=="setup_q22.stm"||htmlstr=="setup_q23.stm"||htmlstr=="setup_q24.stm"||htmlstr=="setup_q25.stm"){
document.write('<font color=#6699ff>Connection Type</font></td>');
else{
document.write('<a href=/wan_main.stm target=_self class="menuharf">Connection Type</a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="setup_dns.stm"){
document.write('<font color=#6699ff>DNS</font></td>');
else{
document.write('<a href=/setup_dns.stm target=_self class="menuharf">DNS</a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="ddns.stm"){
document.write('<font color=#6699ff>DDNS</font></td>');
else{
document.write('<a href=/ddns.stm target=_self class="menuharf">DDNS</a></td>');
</script>
</tr>
<!-- Wireless -->
<tr id="Out3d">
<td width="5">
</td>
<script>
var subhtmlstr= htmlstr.substring(0,8);
if((htmlstr=="wireless_main_0.stm")||(subhtmlstr=="wireless")){
document.write('<a href=javascript:javamagic("Out3","/wireless_main_0.stm",1);
><font color=#ffff00>Wireless</font></a></td>');
}else{
><font color=#ffffff>Wireless</font></a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="wireless_id.stm"){
document.write('<font color=#6699ff>Channel and SSID</font></td>');
else{
document.write('<a href=/wireless_id.stm target=_self class="menuharf">Channel and SSID</a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="wireless_e.stm"){
document.write('<font color=#6699ff>Security</font></td>');
else{
document.write('<a href=/wireless_e.stm target=_self class="menuharf">Security</a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="wireless_wds.stm"){
document.write('<font color=#6699ff>Wireless Bridge</font></td>');
else{
document.write('<a href=/wireless_wds.stm target=_self class="menuharf">Wireless Bridge</a></td>');
</script>
</tr>
<!-- Firewall -->
<tr id="Out3d">
<td width="5">
</td>
<script>
if((htmlstr=="firewall_main_0.stm")||(htmlstr=="nat_v.stm")||(htmlstr=="log.stm")||(subhtmlstr=="firewall")||(htmlstr=="accessControlAdd.stm")){
document.write('<a href=javascript:javamagic("Out3","/firewall_main_0.stm",1);
><font color=#ffff00>Firewall</font></a></td>');
}else{
><font color=#ffffff>Firewall</font></a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="nat_v.stm"){
document.write('<font color=#6699ff>Virtual Servers</font></td>');
else{
document.write('<a href=/nat_v.stm target=_self class="menuharf">Virtual Servers</a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="firewall_a.stm"||htmlstr=="firewall_u.stm"||htmlstr=="firewall_rule.stm"||htmlstr=="accessControlAdd.stm"||htmlstr=="firewall_rule_a.stm"){
document.write("<font color=#6699ff>Client IP Filters</font></td>");
else{
document.write("<a href=/firewall_a.stm target=_self class=menuharf>Client IP Filters</a></td>");
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="firewall_mac.stm"){
document.write('<font color=#6699ff>MAC Address Filtering</font></td>');
else{
document.write('<a href=/firewall_mac.stm target=_self class="menuharf">MAC Address Filtering</a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="firewall_d.stm"){
document.write('<font color=#6699ff>DMZ</font></td>');
else{
document.write('<a href=/firewall_d.stm target=_self class="menuharf">DMZ</a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="firewall_ping.stm"){
document.write('<font color=#6699ff>WAN Ping Blocking</font></td>');
else{
document.write('<a href=/firewall_ping.stm target=_self class="menuharf">WAN Ping Blocking</a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="log.stm"){
document.write('<font color=#6699ff>Security Log</font></td>');
else{
document.write('<a href=/log.stm target=_self class="menuharf">Security Log</a></td>');
</script>
</tr>
<!-- Utility -->
<tr id="Out3d">
<td width="5">
</td>
<script>
var subhtmlstr= htmlstr.substring(0,6);
if((htmlstr=="tl_main_0.stm")||(subhtmlstr=="tools_")||(subhtmlstr=="system")){
document.write("<a href=javascript:javamagic(\"Out3\",\"/tl_main_0.stm\",1);
><font color=#ffff00>Utilities</font></a></td>");
}else{
><font color=#ffffff>Utilities</font></a></td>");
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="system_r.stm"){
document.write('<font color=#6699ff>Restart Router</font></td>');
else{
document.write('<a href=/system_r.stm target=_self class="menuharf">Restart Router</a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="tools_restore.stm"){
document.write('<font color=#6699ff>Restore Factory Default</font></td>');
else{
document.write('<a href=/tools_restore.stm target=_self class="menuharf">Restore Factory Default</a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="system_c.stm"){
document.write('<font color=#6699ff>Save/Backup Settings</font></td>');
else{
document.write('<a href=/system_c.stm target=_self class="menuharf">Save/Backup Settings</a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="tools_backup.stm"){
document.write('<font color=#6699ff>Restore Previous Settings</font></td>');
else{
document.write('<a href=/tools_backup.stm target=_self class="menuharf">Restore Previous Settings</a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="system_f.stm"){
document.write('<font color=#6699ff>Firmware Update</font></td>');
else{
document.write('<a href=/system_f.stm target=_self class="menuharf">Firmware Update</a></td>');
</script>
</tr>
<tr>
<td width="5">
</td>
<script>
if(htmlstr=="system.stm"){
document.write('<font color=#6699ff>System Settings</font></td>');
else{
document.write('<a href=/system.stm target=_self class="menuharf">System Settings</a></td>');
</script>
</tr>
</tbody>
</table>
<td style="BACKGROUND-COLOR: #666262" width=1></td>
</tr>
</tbody>
</table>
</td>
<td valign="top" width="1" bgcolor="#666262" height="100%"><img src="/images/shim.gif" width="1" height="1"></td>
<td valign="top" width="99%" height="100%" class="head_bold">
<br>
ADSL >
ADSL Status<br>
<a NAME="top">
<table width="100%" border=0 class="copy_1">
<tr>
<td width="5" colspan="2">
</td>
</tr>
<tr>
<td width="10" height="25" >
</td>
<td>
<p>
<br><br>
<b>Monitoring Index:</b><br>
<a href="javascript:void(0);
" class="plaintext_bold" onClick="window.open('glossary.stm#adslstat','help','toolbar=0,status=0,menubar=0,scrollbars=1,resizable=1,width=530,height=400,left=150,top=150');
"><b><font color=#6464c3>More Info</font></b></a>
</p>
<ul type="square">
<li >ADSL Status Information:</li>
<ul type="disc">
<li ><a href="#status_i">Status</a></li>
<li ><a href="#rate_i">Data Rate Information</a></li>
<li ><a href="#defect_i">Defect/Failure Indication</a></li>
<li ><a href="#counter_i">Statistics</a></li>
</ul>
</p>
<a NAME="status_i"></a>
<p>
<li >Status:<br><table cellSpacing=1 cellPadding=3 border=0 class=copy_1><tr><td colspan=3 ></td></tr>
<tr bgcolor=#666262><td><p align=center>
</td>
<td><p align=center><font color=#ffffff>Configured</FONT></td>
23-03-2012 11:08 PM
Quote from: stathe This is from use source A
That Source A text contains lots of JavaScript code which is probably why you can't select text from the standard page. The text does contain the downstream and upstream sync speeds, and these should be selectable, but the more important noise margins don't appear to be in that text. I wonder if Source B would provide both?
Rather more experimenting with the page text in a browser would probably be needed to make this work. In fact even then it might not work well with this simple selecter because the location of the values relative to the start of the text might change.
So difficult to identify a way forward with this.
24-03-2012 2:55 PM
