Been Away
- Been Away
Been Away
05-06-2010 8:31 PM
Have been away for a week or so and turned off my router, it is now a problem to recover my old speed ,results for to-day below
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
641 Kbps
0 Kbps 1000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 641 Kbps
For your connection, the acceptable range of speeds is 200-1000 Kbps.
Additional Information:
Your DSL Connection Rate :1184 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 750 Kbps
This profile seems to have been reduced how do I get it back ,and get my speed up to near 1000as it was before, wish I hadnt turned the router off Thanks for any observations
Download Speed
641 Kbps
0 Kbps 1000 Kbps
Message 1 of 6
(915 Views)
5 REPLIES 5
Re: Been Away
05-06-2010 8:40 PM
For that sync rate, you just about fall into the 1000 profile, so unsure why BT have given you a 750 profile. The download speed you have is consistent with a 750 profile....
May be worth waiting a day or so, to see if it recovers, may just be a BT glitch. What are your line stats, if all you get is 1000, and you are happy with that, may be worth asking for a fixed rate connection, although your upstream rate will fall, if thats important to you. MaxDSl didnt work well for my parents, for this very reason, so they went onto a fixed rate, so at no time does it ever fall below 1000.
Hope it helps
Hope it helps
Message 2 of 6
(373 Views)
Re: Been Away
06-06-2010 9:16 AM
Thanks for that, When I was on a fixed rate it was less, so would rather recover,as it was before I went away, Will see if my profile is raised in a few days, or may be raise a ticket, The problem is if I unplug the router again it may restart at alower speed, I think Plusnet have more control than they will admit
Message 3 of 6
(373 Views)
Re: Been Away
07-06-2010 11:38 AM
Hi stathe,
The BT profile was set to 1000 so I've upped our side to match, sorry that didn't happen automatically (though it only changed yesterday so would have caught up).
Message 4 of 6
(373 Views)
Re: Been Away
07-06-2010 12:54 PM
Thank you
Message 5 of 6
(373 Views)
Re: Been Away
07-06-2010 9:21 PM
Hope it stays stable for you
Message 6 of 6
(373 Views)
