Bad speed after product change - ADSL2+?
- Bad speed after product change - ADSL2+?
15-12-2010 9:56 PM
Can some nice staff member tell me if I have been put on ADSL2+? I have just changed from an older product to a new one, and this has coincided with a terrible speed drop. I used to get a 1Mbps profile most of the time, with occasional drops to 750kbps. It is now 135kbps. The sync rate and noise margin are all over the place. I have just fired it up to see 672kbps and 22dB.
I am on a very long line of about 65-66dB, so if I have been given an ADSL2+ that might explain why it has got so much worse.
I haven't tried the master socket yet, because the sync rate is so variable anyway I'm not sure I'd tell the difference!
Message 1 of 7
(5,675 Views)
6 REPLIES 6
Re: Bad speed after product change - ADSL2+?
15-12-2010 10:21 PM
Can you set your router to force ADSL1?
Message 2 of 7
(668 Views)
16-12-2010 10:20 AM
I haven't found any option to do that, though I'm happy to be corrected. It is a 2Wire HGV2700 with Singtel firmware.
Message 3 of 7
(668 Views)
16-12-2010 12:21 PM
Nope, you can't force the mode on a 2700 I'm afraid.
Message 4 of 7
(668 Views)
16-12-2010 12:30 PM
Hi Denzil,
You are definitely on ADSL on 20cn. The profile has been dropped due to a number of disconnections. See below:
How is your kit set up as in test socket/extension cables etc? As the SNR is currently 17dB, which will be keeping your sync rate low.
Jojo
Jojo
Message 5 of 7
(668 Views)
16-12-2010 1:12 PM
Hi, Joanne,
OK, maybe it was just coincidence that it seemed to start when the product changed. I have an ADSL Nation filtered NTE5 faceplate, with the router pugged in on a short cable and a length of CAT5e going upstairs to the PC. Connected to the other side of the faceplate is a single DECT phone on an extension lead.
The Radius graph is interesting. There is definitely something happening in the afternoons, isn't there? Some of the short blips were down to me reconnecting in an effort to get a better sync rate, but I can't explain why it would lose the connection completely between 2 and 5pm. At least, there is no obvious localised reason. I'll do some investigating.
Message 6 of 7
(668 Views)
16-12-2010 1:36 PM
Hi Denzil,
If you do have a test socket behind the faceplate it could be worth trying it with a standard filter in there.
Thanks for your help.
Jojo
Jojo
Message 7 of 7
(668 Views)
