Back to the dark ages
chrisyoung
Ok been with plusnet for years and this is the worst I have ever seen it I have basicly got dail up.
8 REPLIES 8
7up
Fixes: 17
Re: Back to the dark ages
Must be something in your local area - my connection is fine and i'm normal copper adsl that hits 6Mb on a good day.
chrisyoung
No everyone else in my area fine. Just me. Pn have been getting worse will be asking for Mac code tomorrow
7up
Fixes: 17
Strange one then that is.
From our end, PN are very reliable. It hasn't always been that way though, we've had troubles with them in the past so i'm quick to point out when they are at fault but we genuinely have not had any problems for a long time.
I hope PN can fix you up but if you go, I wish you good luck Wink
Pettitto
Fixes: 5
If your connection is problematic, I'd advise running through the <a href="https://faults.plus.net">Broadband Fault Checker</a> and we'll get this looked into for you.
davidj66
Fixes: 4
Wireless issues with your router ?? My wireless speeds declined alarmingly about 18 months ago; turned out to be the router dying as I could get "normal" speeds with a hard wired connection to my laptop
MatthewWheeler
Fixes: 479
Your lines testing fine and you should be getting around 14mbps.
Can you try a wired connection?
 Matthew Wheeler
chrisyoung
Same with wired. Seem ok today. 
Fixes: 160
In which case, you need to keep an eye on it.
Quote from: chrisyoung
Internet speed is very rarely a function of the ISPs service and much more often down to BTOR or a user's internal set up (so changing providers will not help).  Sometimes it can be down to wifi congestion or electrical interference in the user's domain, neither of which are the responsibility of the ISP or BTOR.
The link pointed to by Chris Pettitt might be useful in helping you check out all of the user domain sources of problems.
