Back to abysmal speeds.
- Back to abysmal speeds.
21-12-2011 6:43 AM
Re: Back to abysmal speeds.
21-12-2011 7:07 AM
Pinging portal.plus.net [212.159.8.2] with 32 bytes of data:
Reply from 212.159.8.2: bytes=32 time=1900ms TTL=250
Reply from 212.159.8.2: bytes=32 time=1849ms TTL=250
Reply from 212.159.8.2: bytes=32 time=2595ms TTL=250
Reply from 212.159.8.2: bytes=32 time=2605ms TTL=250
Ping statistics for 212.159.8.2:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 1849ms, Maximum = 2605ms, Average = 2237ms
Modem
ADSL Firmware Version A2pB025c1.d21j2
Modem Status connected
DownStream Connection Speed 11803 kbps
UpStream Connection Speed 443 kbps
VPI 0
VCI 38
21-12-2011 9:27 AM
I can see your results there. Can you tell me if you're using extension cables/sockets? Have you tried the test socket? Is it wireless? I could really do with a bit more than just the results to be fair.
Jojo
21-12-2011 10:01 AM
Sorry about the post,i'm sure you understand how i'm feeling.
Done the test socket, phone is clear no crackles or anything apart from the normal dial tone, no extentions/sockets, just one filter for the phone and router, no wireless. The longest wire is from the router (1.6M new) to filter, the master socket had a new faceplate fitted about 5 weeks (approx) ago by BT when PN called them out for the same issue, Since BT came out i have had sounds coming through the speakers as if i was on the 'old' party line, still get the same sound when i log out of the computer, just thought i'd mention that.
If i'm downloading anything i can't use the net at the same time or it's not worthwhile me using it, as my previous issue, windows or Linux the issue is still there wether the two boxes are connected or one box.
I am beginning to wonder if BT are upto their old tricks of getting customers by interfering with the exchange and pass the buck.
22-12-2011 11:39 AM
22-12-2011 12:44 PM
22-12-2011 2:48 PM
No noises from the test socket or Master (phone only), getting a clean dial tone.
Although the speed test appears to be decent,going of previous comments, the pages are really slow, i have a Netgear router (DGN2200) 5 weeks old(approx), Mobo=M5A78L-M/USB3, bought same time as the router, i've stripped all the hardware out just to eliminate possible issues,but they have made no difference.
22-12-2011 3:27 PM
22-12-2011 3:41 PM
22-12-2011 3:49 PM
22-12-2011 5:00 PM
22-12-2011 5:10 PM
Also, have you run a scan on your machine in case anything is using your bandwidth?
22-12-2011 5:53 PM
22-12-2011 8:51 PM
