BT speedtester up the creek again?
- Re: BT speedtester up the creek again?
26-05-2008 11:59 AM
I have been trying to use the BT speedtester for the past half hour, and I keep getting all sorts of "usual" error notices "exception notice" "wrong user name" etc.,
yet the thing still says "No known problems"
any one else had any luck lately with this infernal testing device?
Message 1 of 6
(1,023 Views)
5 REPLIES 5
26-05-2008 12:05 PM
I should think its for the same reason as the portal problem, speed tester cant access that either
Message 2 of 6
(454 Views)
26-05-2008 12:07 PM
Have no problem with this http://www.mybroadbandspeed.co.uk/
have accessed it at 08:07, 11;00, and just now 12:06 all o.k
jut had another go at BT and still same "exception error"
Message 3 of 6
(454 Views)
26-05-2008 12:18 PM
But mybroadband doesnt ask you for your login, BT does
Message 4 of 6
(454 Views)
26-05-2008 12:48 PM
Sorry Pierre, I thought that was what you meant by... "speed tester cant access that either"
Never mind, will just have to keep trying.... did not know the two systems were linked (P/N portal, and BT speedtester)
Message 5 of 6
(454 Views)
26-05-2008 12:50 PM
I am just guessing as you have to enter you user ID
Message 6 of 6
(454 Views)
