BT speed checker 'manipulated' for better results?
- BT speed checker 'manipulated' for better results?
- « Previous
- 1
- 2
- Next »
Re: Slow and getting slower.
19-08-2017 4:20 PM
19-08-2017 6:34 PM
Sorry, have looked back through the thread and missed this one, is this of any help?
19-08-2017 6:40 PM
And this........
19-08-2017 9:57 PM
@Gandalf - is there any thing amiss with the line stats / history please?
20-08-2017 7:31 AM
63.5 / 31.5 are the maximum attenuation values typically displayed on a line using ADSL1. The actual attenuation could be significantly greater.
Unfortunately there's the chance that this line is on the type of exchange equipment that does ADSL2+ poorly on long lines, so there's the risk that changing it from ADSL1 to ADSL2+ might make it worse.
I'm not really sure why it was concluded that it "will most likely be a poorly performing fibre service" - with the estimated range of 40-60Mb, even at the low end of the estimate FTTC would still be substantially better, whereas a 1Mb connection is probably not enough to comfortably browse modern web sites and the slightest thing trying to update itself in the background is going to take up the bandwidth for a long time.
20-08-2017 10:03 AM
In reply to above, the problem is not the 1Mb ADSL predicted speeds, the problem is the inconsistency of the speeds. My connection is 'acceptable' for what I use it for out of peak hours but drops as low as 0.08Mb in rush hour. That is NOT acceptable.
20-08-2017 12:35 PM
Are there any issues with back haul capacity from this user's exchange?
22-08-2017 1:07 PM
Lack of interest from Gandalf and crt?
Got some time off work, so trying the internet at less busy times and unhappily it's little different. Just clicked on the second page of this discussion and it took a full 29 seconds to fully open. Shamefull really.
03-09-2017 11:11 PM
Thanks for all your help...............NOT.
04-09-2017 7:57 AM
04-09-2017 12:22 PM
Sorry to see we've not followed up here.
I've checked the latest VP report from BTwholesale and we can see that the SVLAN your circuit is connected to at the exchange is below threshold which indicates that there are no reported overutilisation or congestion issues.
When your speed is particularly poor, can you run a speedtest at http://speedtest.btwholesale.com using a wired connection.
Please ensure that no other devices are connected to the router, and there are no open background tasks on the PC you're using. Once you have the result, please complete the further diagnostics. This will store the result on the supplier system.
Thanks,
Anoush
04-09-2017 5:22 PM - edited 04-09-2017 5:58 PM
General surfing, emails etc is acceptable now, managed to improve things myself without the support of this 'community'.
All I did was to get rid of the 2704n router supplied by PN, speeds still slow down at busy times but not to a point where Chrome thinks the connection has dropped.
I will do the speed test, but doubt it will show any issues, I believe they were all down to the router.
04-09-2017 5:34 PM
- « Previous
- 1
- 2
- Next »
