BT speed checker U/S for several days
- BT speed checker U/S for several days
Re: BT speed checker U/S for several days
28-02-2011 7:37 PM
I'm using Windows 7 and Its not working for me, I believe Its nothing to do with the OS as we have all sorts of machines and OS here and some report the same problem.
Quote from: chandu Mind you I used Win7 machine. I believe XP causes this error! I know this is no consolation.
28-02-2011 7:41 PM
http://usertools.plus.net/@gateway
You are currently connected to the gateway known as thn-ag1.
This is located in Telehouse North.
and ADSL2+
28-02-2011 7:42 PM
PS 64 bit Java installed.
Edit pcl-ag07.
28-02-2011 7:42 PM
P.S. I hope you get some good news soon. Thoughts are with you.
28-02-2011 8:12 PM
I didn't mean to upset people.
28-02-2011 8:46 PM
We are all trying different thinks to find why the tester is failing
28-02-2011 9:40 PM
A thought.
A factor that I hope PN bear in mind when addressing this issue is :-:
The numbers of members reporting this difficulty may not reflect the true scale of this problem..
I would suggest that the members reporting the issue via this forum and possibly via support, represent the more " Techie "ranks of the membership,
mostly having a good understanding of the need for knowledge of BT parameters.
At the same time there may be large numbers of members affected by the issue but remaining unaware of it and, i would guess, may have neither used the tester,nor are aware of it's importance.
We may represent "the tip of the iceberg"
Lets hope that more members become aware and thus help raise the profile of this frustrating issue..
Meanwhile, thanks to Jojo for taking up the cause on our behalf.
Mike (edgeways)
01-03-2011 6:48 AM
when I switched on this morning I had to dis and reconnected the router, still on
01-03-2011 9:18 AM
edgeways
01-03-2011 9:42 AM
(ptn-ag01)
01-03-2011 9:51 AM
01-03-2011 9:58 AM
01-03-2011 10:03 AM
Thanks for all your help. I've collated all the examples you've sent me and an email has been sent so we'll see what we get back.
Jojo
01-03-2011 10:03 AM
I've just PM'd your service ID as requested.
Jojo
01-03-2011 10:08 AM
We have an internal problem raised about this now (ref: 66042), and as JoJo mentioned earlier the examples you've all provided have been sent over to the Speedtest developers/our BT account manager. We'll report back if/when we find anything out...
