BT have raised my SNR margin, despite my line being stable
- BT have raised my SNR margin, despite my line bein...
- « Previous
- Next »
Re: BT have raised my SNR margin, despite my line being stable
08-10-2009 9:05 AM
@James: Please can you supply me with the information mentioned in Anotherone's last post (exact dates and times of analysis & whether the resync was due to the test).
@Anotherone: I spent months looking for sources of interference within my house. I could not find any. Despite the speed problems on my line I have very few resyncs and none in recent history (apart from the one that may be caused by the recent test) [I am not counting manual reboots and ones triggered by noise margin changes]. There may be too many errors according to BT to keep my target margin low, but I have no idea how many that would be.
Message 46 of 54
(548 Views)
08-10-2009 10:35 AM
Hi mapletree,
The test would have been run a few minutes before the ticket was updated, so about 5pm is right - and it looks like partial results from a one shot check, which may well have knocked the sync out briefly. I'm not 100% sure but it is the most likely reason, and was run at around the right time.
Message 47 of 54
(548 Views)
08-10-2009 3:10 PM
Thanks for the info. Is there any news on the other point (date/time of the analysis period on my ticket)?
Message 48 of 54
(548 Views)
08-10-2009 3:43 PM
The default period is the past 3 days, I'm fairly sure that even if we specify a different time period in the test it still checks the past 3 days anyway. We don't often change those dates so it's a fairly safe bet the analysis period was for the 3 days before and including the test date.
Sorry I missed that off,
Message 49 of 54
(548 Views)
08-10-2009 4:03 PM
The table that contains the analysis data also shows the date of 26th September, which is more than three days before the test. Therefore I think the analysis data must be from earlier. Doesn't anyone actually know?
Message 50 of 54
(548 Views)
08-10-2009 4:06 PM
I'll try and find out.
Message 51 of 54
(548 Views)
08-10-2009 4:18 PM
It's the RRT test (Reactive Repair Tool).
It looks back 14 days.
Message 52 of 54
(548 Views)
09-10-2009 6:27 PM
So it would have covered the period where my target margin was changed.
Upstream margin is constant at 17dB even into the evening.
Message 53 of 54
(548 Views)
14-10-2009 8:58 PM
It's going from bad to worse again. A few drops and an even lower sync speed now
Does this make sense to anyone:
Counters Down Up
SF: 24307 24306
SFErr: 0 0
RS: 826458 205598
RSCorr: 44 0
RSUnCorr: 0 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 2152032
Data Cells: 13703
Drop Cells: 0
Bit Errors: 0 0
ES: 618 0
SES: 3 0
UAS: 164 0
AS: 414
INP: 0.73 1.00
PER: 1.91 1.96
delay: 4.36 4.50
OR: 29.30 28.44
Bitswap: 0 0
Total time = 1 days 6hours 15min 25sec
SF = 11474901 CRC = 2147
LOS = 3 LOF = 27 ES = 618
Latest 1 day time = 6hours 15min 25sec
SF = 1322483 CRC = 540
LOS = 1 LOF = 9 ES = 81
Previous 1 day time = 24hours 0sec
SF = 5082319 CRC = 333
LOS = 0 LOF = 0 ES = 260
Message 54 of 54
(548 Views)
- « Previous
- Next »
