BT Wholesale Diagnostic Test
- Re: BT Wholesale Diagnostic Test
23-01-2014 11:29 AM
Are we all getting fed up & tired of kept doing first page test before next page to do a further diagnostic test to get your ip profile?
Well, not anymore, you can ran BT Wholesale run diagnostic test straight away to get your ip profile. Please note: Speedtest throughput isn't correct. Use a normal BT speed test here: http://www.speedtest.btwholesale.com/
Quickest way to check ip profile here: http://www.speedtest.btwholesale.com/PerformanceTesterWS/diagnostics.do
Message 1 of 8
(1,982 Views)
7 REPLIES 7
23-01-2014 12:01 PM
There is a purpose to the first test though - I believe the ISPs can see your results.
Message 2 of 8
(1,447 Views)
23-01-2014 12:04 PM
I think ISP's only interesting is your IP Profile rate on your line. The first page of test only show throughput speed without ip profile. The 2nd test page (further diagnostic) is showing both throughput speed and ip profile.
Message 3 of 8
(1,447 Views)
23-01-2014 12:56 PM
This post has been updated http://community.plus.net/forum/index.php/topic,96155.0.html
However I have run the test twice both giving this result
So something is a bit adrift
Quote Upload speed achieved during the test was - 0.01Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Message 4 of 8
(1,447 Views)
23-01-2014 1:09 PM
Are u running this test from your Fibre? Or just standard ADSL/ADSL2+?
Message 5 of 8
(1,447 Views)
23-01-2014 1:14 PM
standard and others are seeing the same result http://forums.thinkbroadband.com/btsupplier/f/4298498-bt-wholesale-diagnostic-test.html#Post4298525
Note that an IP profile of 0.83Mbps on Fibre wouldn't be very good
Message 6 of 8
(1,447 Views)
23-01-2014 1:36 PM
RobertoS had done his test with fibre as it did show ip profile on both downstream and upstream on his fibre but upload throughput is still not right. His downstream/upstream ip profile showing as: 57.51Mb and 20Mb
Message 7 of 8
(1,447 Views)
23-01-2014 2:34 PM
Can you please note - my post was in reference to the upstream speed and nothing to do with IP profile which is correct
Message 8 of 8
(1,447 Views)
