BT Speedtester
- Re: BT Speedtester
BT Speedtester
12-11-2012 4:43 PM
Just get the following error in FF, Chrome and IE (all latest versions) and Java installed and enabled:
Quote The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
Is it broken - haven't used it since leaving PN last Feb and coming back today?
Forum Moderator and Customer
Re: BT Speedtester
12-11-2012 4:49 PM
Re: BT Speedtester
12-11-2012 4:58 PM
It's changed since I last tried some 9 months ago. Is there really a need to close all programs, reboot modem, restart browser and do a jig before commencing the test?
Re: BT Speedtester
12-11-2012 5:02 PM
Re: BT Speedtester
12-11-2012 5:07 PM
I'll try later or tomorrow.
Re: BT Speedtester
12-11-2012 7:14 PM
Re: BT Speedtester
12-11-2012 7:50 PM
Re: BT Speedtester
13-11-2012 12:15 AM
Re: BT Speedtester
13-11-2012 12:29 AM
Re: BT Speedtester
13-11-2012 9:54 AM
Re: BT Speedtester
13-11-2012 10:33 AM
Quote from: Anotherone I'm pretty sure you actually end up on the same tester when you do the further diagnostics. Anyway, all works here.
As far as I am aware the http://speedtest.btwholesale.com doesn't use Java which causes a number of issues at times.
Re: BT Speedtester
13-11-2012 10:35 AM
Re: BT Speedtester
13-11-2012 11:28 AM
Now added to the information required to diagnose speed problems http://community.plus.net/forum/index.php/topic,96155.0.html
Re: BT Speedtester
13-11-2012 12:05 PM
Interestingly the two Diagnostic testers were and still are interlinked, in that you cannot run another Diagnostic Test within 10 minutes, whichever tester you had used previously, and no more than 3 in an hour even though one uses Java and the other Flash.
The Beta Flash Tester at http://speedtester.bt.com/ is the same tester as the Initial Flash test at http://speedtest.btwholesale.com/.
Re: BT Speedtester
13-11-2012 12:14 PM
Thanks for adding it to the 'Diagnose Speed Problem' page Oldjim, that's actually a great help
